Replacement Headlining
I suggest you find a local (classic car) trimmer. He can remove it, repair it and replace it.
It will not be a cheap job but it will be good.
Ideally someone who works for himself.
sticks very quickly so you do not want to "mis-position it".
You do have to take down the sunroof frame to get out the slider.
The material is available on Ebay.
Polymat 797 Hi Temp Spray Adhesive 20oz Can high temperature headliner glue 160
Jaguar XJR Type Auto Headliner Material Fabric 1/8" Foam Back - Lt Tan 120" from Headlinermagic
Others in this forum have found experienced shops to do the job for very reasonable prices I should add.
IIRC, Tberg over in the X150 XK forum was getting custom headliner materials for some of the guys & gals in that section. Might be worth a PM to see if he can get you set up. There should be a thread on it there too
I am still deciding whether to use either suede of knit cloth. I suppose I should do the rear shelf while I am at it. Any tips on shelf removal after the rear seat is out? I have the VDP sun blind.
hasslesnt
Aug 13, 2011 01:05 PM
