Shifter Behavior
Old Jun 26, 2013 | 07:17 AM
oldmots's Avatar
Default Shifter Behavior
I've just noticed that the shift lever does not hit the bottom of the gate in drive. The tranny seems to be in drive, but the shift lever stops about 1/4" before hitting the bottom of the slot. I looked at the cable bracket underneath and it is secure. The lever will go around the left into the J gate as it should. Just curious if anyone has an idea on this one? I have never heard of this before.
Old Jun 27, 2013 | 03:15 PM
Fraser Mitchell's Avatar
Nor me. It might be prudent to inspect the shift lever assembly. Might be a stuck/seized detent. Wear does occur on these things after high miles; they are not ever-lasting, unfortunately.
Old Jun 28, 2013 | 12:17 PM
oldmots's Avatar
I hate to pull the console apart but something may be blocking the shifter so I guess I'll have to dig into it.
Old Jun 28, 2013 | 12:41 PM
oldmots's Avatar
Well, I pulled the surround and looked into it. As I thought, a large piece of plastic debris was blocking the shifter from seating in drive. It looks like it has been broken awhile, the broken edges were dusty. I removed it with a long nosed tool and all seems well. This broken piece is part of the housing which includes some kind of ramp. the shifter works normally, so I'll try to forget about it.
Old Jun 30, 2013 | 07:24 AM
That's the problem with used cars, the bloke who fiddled about before you bought it.
Old Jul 2, 2013 | 10:44 AM
oldmots's Avatar
Its strange that this would happen now, since I've had the car since 2007. I have not pulled down the shifter to see where the piece came from, but it looks like some impact caused it. I didn't do it, but maybe the valet at the last hotel I was at in Savannah? I'll never know.
n2audio
19
Jan 20, 2025 09:35 PM
workworkwork
Oct 23, 2015 10:26 AM
adam699
Oct 13, 2015 05:53 PM
Johnken
Oct 2, 2015 10:12 AM
Johnken
Oct 1, 2015 05:07 PM
