Some side of the engine sensor leaks oil
Old Jul 1, 2018 | 11:22 AM
rf69's Avatar
Default Some side of the engine sensor leaks oil
Hello fellows,
Some side of my XJ8 2004 engine sensor leaks oil.
my Jag has 207,254 miles and it’s been good to me only problem I had was replacing the Airshocks and Compressor.
I don’t know the name of that sensor but it’s on both side of the engine when you open the hood .
Can someone tell me the name so I can get the part
pictures attached
thanks
Old Jul 1, 2018 | 12:17 PM
Box's Avatar
Box
VVT oil seal, AJ82856
Old Jul 2, 2018 | 11:08 AM
rf69's Avatar
oh ok, thanks ,
are the VVT oil seal easy to replace ?
can I do the work myself ?
Old Jul 5, 2018 | 05:55 AM
Box's Avatar
Box
Originally Posted by rf69
oh ok, thanks ,
They simply press in from the top. Use a small blade screwdriver under the edge and pop them out, then clean the surface with a rag and hand press the new one in.
Old Jul 6, 2018 | 09:36 AM
rf69's Avatar
i did it , easy
thanks
mmindling
Feb 7, 2017 06:19 PM
jag79
Feb 25, 2016 01:14 PM
Rotomike
Mark V - X 420G
May 6, 2015 11:43 AM
daxter1987
Jan 26, 2015 01:56 PM
mda419
Jan 20, 2015 12:01 PM
