'spectacle' oil seal change
Old Aug 15, 2025 | 12:18 AM
meirion1's Avatar
Default 'spectacle' oil seal change
I am referring to the oil filter housing.
What is the procedure to change the seal please?
Drain all engine oil first?
Old Aug 15, 2025 | 11:31 AM
redrover41's Avatar
Default Correction
I found this using AI:
Oil Filter Housing Seal Replacement Checklist: 2003 X350
Prep & Safety
  • [ ] Park on level ground, let engine cool
  • [ ] Jack up front end, secure with jack stands
  • [ ] Disconnect battery (optional but recommended)
Drain & Access
  • [ ] Remove splash shield (8mm or 10mm socket)
  • [ ] Drain engine oil (13mm drain plug)
  • [ ] Remove oil filter cap (76mm 14-flute socket)
  • [ ] Remove oil filter and allow housing to drain
Housing Removal
  • [ ] Disconnect any sensors or hoses from housing
  • [ ] Remove housing bolts (Torx or 10mm socket depending on engine)
  • [ ] Carefully remove housing and old gasket
Seal Replacement
  • [ ] Clean mating surfaces thoroughly
  • [ ] Install new gasket/seal (lightly oil if rubber)
  • [ ] Reinstall housing and torque bolts to spec
Reassembly
  • [ ] Install new oil filter and lubricate seal
  • [ ] Torque filter cap to spec
  • [ ] Reinstall drain plug with new crush washer
  • [ ] Refill engine oil (see capacity below)
  • [ ] Reinstall splash shield
  • [ ] Start engine, check for leaks
  • [ ] Verify oil level after short run
🔩 Torque Specs & Oil Capacity
Component
Torque Spec
Notes
Oil filter cap
25 Nm (18 lb-ft)
Use proper socket to avoid cracking
Oil filter housing bolts
25–28 Nm (18–21 lb-ft)
Confirm bolt type (Torx vs hex)
Drain plug
30 Nm (22 lb-ft)
Replace crush washer
Engine Variant
Oil Capacity (with filter)
Oil Type Recommendation
4.2L V8
~7.5 quarts (7.1 liters)
SAE 5W-30 (Jaguar spec)
3.0L V6
~6.6 quarts (6.2 liters)
Hope it is of value for your project.
rsa
Old Aug 15, 2025 | 03:08 PM
Thomas-S.'s Avatar
No need to drain all the oil, as the filter housing is above the oil pan, but you will have some oil draining from the filter and the filter housing.
The replacement is pretty much straightforward and basically as described in the previous post. If needed, I can share the relevant part of the workshop manual.
Best regards,
Thomas
Old Aug 15, 2025 | 05:25 PM
meirion1's Avatar
Brilliant detailed replies !
Thank you for both.
Bob
DevilDog
Jun 10, 2024 05:11 AM
Rex
Aug 28, 2023 10:26 AM
xjack
Nov 24, 2020 01:15 PM
Nos_Monkeys
Dec 29, 2013 05:37 AM
RRT
Jun 17, 2013 06:03 PM
