Starter problems
Old Nov 15, 2019 | 08:54 AM
blj54's Avatar
Default Starter problems
Can some one help me find information on changing the starter on my 2006 XJ Vdp please
Do I have to remove the motor mount to get top bolt out
Old Nov 15, 2019 | 11:02 AM
Wingrider's Avatar
Top bolt is a problem, took the motor mount out, & replaced alternator at the same time on mine.
Long extensions were used to access it.
The top alternator bolt is also a problem, it has a wire in the way.
Old Nov 15, 2019 | 02:40 PM
meirion1's Avatar
I have never done it but you may be able to do it with a curved spanner.
Old Nov 15, 2019 | 03:50 PM
Wingrider's Avatar
Thumbs up
Curved spanner, never thought of that one, that just might work.
Old Nov 21, 2019 | 09:35 AM
blj54's Avatar
Thank you all for the response. I tried changing starter with car up on car ramps and decided to get a starter and alternator and took it to a long time friend and fellow mechanic should get it back in a couple of days. Safe driving everyone
Old Nov 23, 2019 | 04:57 PM
Wingrider's Avatar
Yes i did both at the same time too, but waited till i had use of a lift.
Even then, & with some help, it was not that easy a job, glad it's done now on both cars.
They all seem to need a good bit of maintenance caught up, & with needed suspension parts.
Old Nov 24, 2019 | 04:42 PM
blj54's Avatar
I did go to Harbor Freight and found a set of S wrenches (under $20.00) my mechanic said starter change under 20 Min also had him change the Transmission cooling Hose.
mx468
Apr 16, 2018 08:48 AM
razorboy
Nov 11, 2015 10:24 AM
ssearle
Apr 16, 2014 02:04 PM
mbs xk8
Sep 15, 2013 07:14 PM
