Starting problems
Hi, I have a 1984 XJ6 Vande Plas series 3 has been sitting for 5 years with 21,000 miles. the problem is it tries to start and will do this twice then it will just crank. Any ideas on what to do to get it started? And it ran just fine when stored and put into a garage.
I drained both tanks changed fuel filter and installed new fuel pump and installed fresh gas. I also removed spark plugs and sprayed fogging oil in the cylinders with a 1/4 cup of Royal Purple engine brake in oil to lubricate the rings and cylinder walls. I am in the process of installing new injectors and Mass air flow unit. I hope that this will take care of most of the problems in the fuel line. Any suggestions ? Remember this car ran before it was stored and by the way, I also put a new battery in.
I know battery will drain but fuel pump may old?-- Is it a diaphragm pump or perstalic?
