Starting problems
Old Aug 13, 2020 | 10:49 AM
Big 23's Avatar
Default Starting problems
Hi, I have a 1984 XJ6 Vande Plas series 3 has been sitting for 5 years with 21,000 miles. the problem is it tries to start and will do this twice then it will just crank. Any ideas on what to do to get it started? And it ran just fine when stored and put into a garage.
Old Aug 14, 2020 | 10:46 AM
Rickkk's Avatar
I don't know about the 1984 XJ6 Vande Plas, but you could try placing a jump on the battery for a few minutes. If it starts, then the battery may be due for a replacement.
Old Aug 15, 2020 | 08:29 AM
brian5's Avatar
Did you put fresh fuel in it?, fuel does go off after sitting, might just be stale fuel, or a clogged filter, possibly the fuel pump, but I would start with fresh fuel
Old Aug 24, 2020 | 10:01 AM
Big 23's Avatar
Default 84 xj6 jag starting problems
I drained both tanks changed fuel filter and installed new fuel pump and installed fresh gas. I also removed spark plugs and sprayed fogging oil in the cylinders with a 1/4 cup of Royal Purple engine brake in oil to lubricate the rings and cylinder walls. I am in the process of installing new injectors and Mass air flow unit. I hope that this will take care of most of the problems in the fuel line. Any suggestions ? Remember this car ran before it was stored and by the way, I also put a new battery in.
Old Aug 24, 2020 | 12:46 PM
JaguarPwned's Avatar
Is the fuel pump going out a common issue?
I know battery will drain but fuel pump may old?-- Is it a diaphragm pump or perstalic?
bob peers
Feb 29, 2016 10:59 AM
ken_jag
Jun 1, 2013 11:29 PM
introvertimages
Photography
May 16, 2011 10:57 PM
cward
Jul 10, 2008 08:06 PM
