Suspension in hard mode, how to tell?
Old Mar 20, 2013 | 11:39 PM
raschwar's Avatar
Default Suspension in hard mode, how to tell?
2006 xjr. I can feel everything in or on the road. The other day I was riding in the passenger seat (a rare occasion) and was surprised how harsh the ride was.
I know I have the sport suspension and I also know how the car feels when I had a suspension fault and the car rode like it had NO shocks. Is that the hard setting or is that like "no setting". I have no reference point so how can I tell if my shocks are riding normal or hard?
I had the ride height sensors re-calibrated after I installed the front struts so I guess if there were any codes they were cleared. But I did have a suspension fault after that. Would that fault cause a hard mode setting and would that setting ever go away without a dealer clearing it?
Is there a way to determine what setting the suspension is at (without a trip to the dealer)?
Old Mar 21, 2013 | 07:05 AM
oldmots's Avatar
As far as I know, only the dealer computer can set the air suspension settings.
Old Mar 21, 2013 | 01:12 PM
Fraser Mitchell's Avatar
AFAIK, it is only the shock that can switch between Hard and Soft modes, the spring rate remains the same.
Old Mar 21, 2013 | 05:41 PM
meirion1's Avatar
As far as I can gather the two wires to the top of each strut connect to a solenoid inside the strut
This solenoid is part of the CATS system and I assume this is what you are switching when you select sport mode.
If you have had an air suspension fault you might try searching for codes,especially CATS codes and deleting them.
If Brutal comes along maybe he can enlighten us on this.
Old Mar 21, 2013 | 08:59 PM
raschwar's Avatar
Thanks for the replies guys. To clarify, I don't have a selectable suspension. The R comes with a sport suspension which is harsher than the standard XJ. But I think there still may be a hard and normal mode. I'm wondering if there is some why to tell if mine has been set to hard via a suspension fault. If I unplug the connectors on the air struts will this put the suspension in hard mode? If it does then I can tell by feel.
Is it true that once the suspension is set to hard mode by having a suspension fault that it stays in hard mode until the code is cleared or will it revert back to normal mode once the fault is gone? I may be in normal mode for all I know but I would like to know (without paying $125 to the dealer).
Thanks again
Old Mar 22, 2013 | 08:40 AM
There is nothing in my Techical Notes of 2003 concerning a hard and soft setting for the air springs, only the shocks via the CATS system. I have a Sport which has same springs as you, and do find the ride a bit hard at times, but no faults come up.
The Notes state that if a malfunction is found in the adaptive damping or the air suspension, the system defaults to 'Hard' setting for the shocks, (dampers), however, it doesn't state what happens if the fault message disappears, as does happen when the compressor is on the way out and warmer weather comes along.
YOu are correct the suspension is not selectable, as CATS is automatic, but you can select Sport mode for the transmission.
Old Mar 22, 2013 | 09:26 AM
raschwar's Avatar
Thanks. I misread your post about the sport mode, sorry. I guess my terminology is wrong for springs, struts and shocks. Prior to replacing the front units, which were leaking in cold weather, I got constant faults and the nose of the car was quite low. When driving in this condition the ride was EXTREMELY harsh as if there was no cushioning at all. Once the suspension warmed up and started working the ride got much better but still pretty stiff.
This happened once when I was going to the dealer. When I got there he asked me to restart the car and the suspension fault cleared. Then he had the car taken inside to "clear the code". This is one reason I'm wondering if the setting remains after the suspension recovers.
I was at the dealers yesterday for another issue and didn't think to ask them (probably subconsciously thinking it would cost me). But when I go back I will.
Old Mar 25, 2013 | 10:41 AM
Rickard Olsson's Avatar
When mine fails in the cold and runs hard or low, it goes back to normal/soft automatically when the problem goes away (ie the weather gets warmer). I do not have to clear any codes or reset the suspension.
Old Mar 25, 2013 | 12:06 PM
raschwar's Avatar
Thanks Ritchie. Mine are probably operating correctly then. I guess hard is when they are deflated or with a fault and I feel like I'm riding without any suspension and "soft" is when they are inflated. So an R's "soft" is just tight, as it should be.
Forcedair1
Sep 8, 2025 01:57 PM
Forcedair1
Feb 19, 2020 01:51 PM
ogorir
Jan 18, 2016 10:09 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
