Swapping EPB Caliper/Handbrake Cables from one EPB to another from a different Model
Old Today | 09:34 AM
Mini543's Avatar
Default Swapping EPB Caliper/Handbrake Cables from one EPB to another from a different Model
Hi everyone, Okay, so I'm in a bit of a quandary over what will fir what here ? My model is a late 2008 XJ358 V6 Petrol, pretty sure it needs a replacement EPB as per my other thread on here, thing is, after much cross referencing, phone calls to trusted independents, my own knowledge etc: I am pretty sure providing you
get compatible models "same year build 2008 /09" .... You can actually fit another EPB from a donor car that doe not have to be an XJ358? for example ...a late S Type, the 2008 to 2009 model XF, and even a few XK's of the same years ........ So, my question is: Has anyone ever fitted an EPB actuator motor out of a donar car that "wasn't
necessarily an XJ350/358 ? and if so, are the cable set ups the same, Or, do you simply swap your original cables over to the replacement EPB if there is a length difference etc ?
Please see attached Info on this issue, and the part numbers on the replacement 2009 XF I'm thinking of using .........( PS: I have found a 2004 XJ350 EPB that apparently works fine, but as usual it looks old and rusty and is of course four years older than the one I'm replacing.
Many Thanks to all .........
Karam93
XF (X260)
Feb 4, 2020 01:31 AM
JAG9709
Aug 31, 2019 10:16 AM
Cessna_Pilot
May 13, 2019 05:51 AM
YYZ
Aug 15, 2013 07:47 PM
GT42R
Jul 11, 2012 11:20 AM
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests)
