Throttle body help??
Old Aug 19, 2024 | 08:22 AM
Deepstuff's Avatar
Default Throttle body help??
Hi,
I'm having issues with my Throttle body or TPS? What's the circled connector in the pictures - tb motor connections? Can the connector b unbolted and removed/refitted without issue? Any loose or parts or adjustments inside? I want to remove it so I can check the previous repair (looks like pins soldered to end of harness?). Also, if I need to remove the TB , can I unbolt the black plastic part to allow for easy removal of TB? Any reason not to use this connector on a new TB if I need to replace my TB?
2005, VDP 4.2L
Can I remove this circled connector from the TB? Is there anything spring loaded or loose parts to be aware of or any adjustments i shoukd b aware of?
Looks like otiginal harness connector was removed by previous owner and new pins installed on harness?
Old Aug 20, 2024 | 07:28 AM
04Xjrsteve's Avatar
Default R U Looking At the Throttle Body
I just removed & reinstalled my throttle body while replacing hoses. What I see in your pictures doesn't look like the TB. It may well be & I'm just not seeing it correctly.
Wish I could be more helpful.
Best,
Steve S.
Old Aug 20, 2024 | 08:47 AM
Deepstuff's Avatar
Best,
Steve S.
it's the connector for the throttle body motor.
Old Aug 21, 2024 | 01:59 AM
Pete M's Avatar
Hi Steve,
That's because it's a normally aspirated motor not a supercharged one like ours.
Pete M
Old Aug 26, 2024 | 11:17 AM
redrover41's Avatar
https://www.ebay.com/itm/255564960393
WPT-1269 is female connector. If male connector is ok, the 1269 will fit perfectly. Wires from the new connector to the appropriate wires in the wiring harness can be crimped (seller provides hardware), or soldered and covered with heat shrink.
mhamilton
Jan 24, 2024 09:49 AM
fuzzyhippo
Jun 2, 2022 10:46 PM
Peet Venter
General Tech Help
Jan 7, 2020 10:39 AM
Rkhlopin
Nov 11, 2014 08:37 PM
silverj
Apr 6, 2010 02:17 PM
