Tool sizes needed to swap out a shock?
hey everyone I found a video that shows how to swap out a shock but none that show the tools needed.
In the vid it looks like he has a massive unknown size Torx bit connected to a 1/2 drive & ratchet and would like to know any other uncommon size tools that I am gunna need?
Need to buy a bentleys service manual for this car if they make one so I don't have to ask these types of questions in the future
Thanks for any help, even if you only know one of the sizes that would be great
Hey buddy I found out that the torx bit is a T-60 (its the shock bolt that mounts it to lower control arm I believe
everything else should be pretty standard (under 20mm sizes, someone please correct me if im wrong)
Aloha
Aloha
T-60 is correct, and the Allen key is nothing special.about middle of the standard set.
Oh, and the upper a-arm is an 18 mm, which is kinda henky...I happened to have a socket in that size to break it loose and used a 3/4 in rachet w/ allen key to get the rest of the way.
My lesson learned.on my shock replacement...don't drop that 4mm ferrule form into the engine bay when you replace it with the new one that comes with the arnott unit...oh the misery
Sent from my Epic 4G using IB AutoGroup
BrentGardner
29
Dec 16, 2024 12:13 AM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
Aug 25, 2015 07:54 PM
