TPS Sensor Help
Old Oct 18, 2020 | 06:41 PM
IcedGingerBread's Avatar
Question TPS Sensor Help
My 2005 XJR has finally started hitting "Limp Mode" enough for me to replace my TPS sensor. Digging around these forums along with the confirmation of my scan tool, my TPS sensor needs replacing.
First I replaced my battery (was about that time anyways)
Next I installed a new TPS sensor being as careful as possible to align it in the same orientation as the old one. Plugged the battery back in and immediately the car goes into Engine Systems Fault mode. Before I had around 30 seconds up to 5 minutes until this would happen.
Thinking that maybe my new TPS sensor was not aligned properly I tried a few different orientations. Still no luck. I even took the old TPS of my X-Type and tried that. No signs of progress.
I can buy a new throttle body for around $300 right now. Is this my next step?
I've been digging around here for a while trying to find something I missed. If you think I did please let me know. Thank you in advance!
Old Oct 20, 2020 | 08:02 PM
meirion1's Avatar
I suppose that if it was a TPS sensor wiring fault the code would be different.
Have you checked the plug and wiring?
What make of sensor did you buy and how much did you pay?
Try cleaning it.
Old Oct 20, 2020 | 08:32 PM
My plugs are not in the best shape. I just ordered the two pig tails I need, along with a new throttle body.
Should be in around the 26th. Thanks for the reply!
Quinn Thurman
Dec 9, 2020 11:40 AM
jaimster
Aug 18, 2020 08:38 AM
Ijgabloo
XJ40 ( XJ81 )
Sep 5, 2019 11:56 AM
Vandyone
Jul 26, 2018 01:19 PM
Terryconn
Sep 25, 2017 04:34 AM
