transmission
Old Dec 2, 2017 | 01:14 PM
emyngoye's Avatar
Default transmission
transmission overheating leading to spillage of radiator coolant
Old Dec 2, 2017 | 02:39 PM
Fraser Mitchell's Avatar
Hi emyngoye
Are you going to tell us anything more about this car ?
Old Dec 2, 2017 | 03:06 PM
emyngoye's Avatar
Well the car was not shifting well; however some traces of oil was found in the radiator. Apparently mixing with the Transmission fluid. Radiator was changed, but that seem to have solved the problem for a day. After which the gearbox gets over heated and coolant just spills out from any weak spot.
Old Dec 2, 2017 | 03:11 PM
NBCat's Avatar
When seeking help on the forum, it's always quite helpful to provide those responding with the MY, engine type and size and other useful information such as stored DTCs. It's also useful to let everyone know what symptoms you observed and road conditions that caused the issue to occur.
Old Dec 2, 2017 | 03:21 PM
emyngoye's Avatar
engine is a V8 4.0L
Old Dec 2, 2017 | 03:50 PM
abonano's Avatar
engine is a V8 4.0L
Well, your radiator has no provisions for transmission cooling if you have the 4.0 V8 so your radiator issues have zero to do with the transmission.
Old Dec 2, 2017 | 03:51 PM
abonano's Avatar
engine is a V8 4.0L
To add the radiator only carries coolant, no transmission fluid. If you have traces of oil then it's engine oil and you have bigger issues than your transmission.
ecamiel
Nov 14, 2019 07:28 PM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
RUSS
XJ40 ( XJ81 )
33
Sep 24, 2010 04:09 PM
sjuraud
Aug 28, 2010 02:11 PM
JimC64
Sep 10, 2009 12:44 PM
