Transmission
Old Nov 27, 2020 | 04:52 PM
Curley's Avatar
Default Transmission
I just got in the 2000 XJ8 VP and when I went to pull the lever into drive, not happening! I shut the car off, started it again, and still can't get it out of park. I removed the small screw, stuck the key in the hole, shifted it into N then started the car, put it into drive and off I went. I'm at a total lose as to what the heck is going on... Any ideas would be GREAT...
Curley
Old Nov 27, 2020 | 06:21 PM
motorcarman's Avatar
Brake pedal switch??????????????????
Old Nov 29, 2020 | 01:51 AM
paydase's Avatar
Or the screws under the gearbox tunnel, or the solenoid in the gaiter mechanism...
Old Dec 2, 2020 | 12:07 PM
Jberry20's Avatar
To clarify, will the shift lever physically not move to the D position when pressing the brake or the car does not move when you move the lever to D? I just had the latter problem - took a few moments for the transmission to pump up pressure then it was fine. Turns out I had a small leak due to a pan bolt backing out a bit. Tighten the bolt, a couple of pints of fluid and its working fine.
Tazbert
Apr 7, 2021 01:23 PM
tomcoo
Oct 15, 2020 05:51 PM
chaddm55
22
May 30, 2019 04:15 PM
amcdonal86
Nov 18, 2018 01:15 PM
Rlover
Mar 30, 2016 10:04 PM
