Transmission failure
Old Feb 28, 2015 | 09:37 PM
dsetter's Avatar
Default Transmission failure
So my friends xj8 came up with "transmission failure". Carr has done 75k miles. When I drive it now, I do not get the message but do get wild flare on some shifts 2-3 or 3-4. I checked fluid level and found it was about 2 QTS low. I happen to know that PO changed fluid at home but may not have filled to level correctly. We still get transmission slips with correct fluid level.
When driving, manually, each gear seems to drive OK.
I am thinking that there may be sticky or bad solenoids, or the mechtronic module transmission seal may be leaking.
Am looking for suggestions on diagnosis.
Should I look to change solenoids, and fluid and seal, or is it a bigger issue?
Old Feb 28, 2015 | 09:49 PM
MarcB's Avatar
Hey neighbor! I'd start with changing the fluid and filter, then re flash the TCM. The fluid fill is an issue, hopefully there's no long term damage. There are also known issues with the sleeve in the transmission that leaks and may have introduced contaminants. I'm not sure what year the car with the issue is but I think the issue was consistent with most X350s.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
jtflanaga
Sep 28, 2015 01:55 PM
Tim Goz
Sep 17, 2015 09:11 AM
mrplow58
Sep 9, 2015 11:27 AM
