Trunk lid won't lock / unlock
Old Jul 28, 2010 | 07:14 PM
Alex B's Avatar
Default Trunk lid won't lock / unlock
2004 XJ8 electric lock for the trunk lid has stopped working (on key fob, on dash, on trunk lid . . . nothin ! ). There's a motor which pulls the lid down tight so even though I was able to open it manually using the key, if I close it manually (without the electronics) I really need to SLAM the lid to get it to latch (and I don't like slamming ANYTHING on my Jag). I can't find anywhere in the owner's manual where the fuse is located for this switch or motor.
Old Jul 28, 2010 | 07:59 PM
joycesjag's Avatar
I know the S Type guys have a valet switch in the glove box that when "accidently" pushed causes the same issue.
Old Jul 29, 2010 | 10:43 AM
Alex B's Avatar
Thanks for the suggestion. My XJ has the valet button on the dash so I tried arming and disarming it and . . . nothing - it must be a fuse or a relay but the manual doesn't indicate where either of these are.
Old Jul 29, 2010 | 07:52 PM
meirion1's Avatar
You need to get a copy of the Electrical Guide for the X350. It has detailed
circuit diagrams. I have not had this problem fortunately but i have had to replace a door lock/actuator. I traced the fault to the actuator microswitch. These switches have a limited life and I know that there are at least two in the boot lock. Sorry can't help anymore but if it was mine I would check the fuse and if that 's ok dismantle the lock and test it on the bench.
Old Jul 29, 2010 | 11:50 PM
QuadManiac's Avatar
Full electrical diagrams for your car are here:
http://www.captainjaguarscathouse.co...ec%20Guide.pdf
Old Jan 7, 2012 | 06:25 AM
AnthonyF's Avatar
Alex B how did you fix this problem?
BadKat174
May 26, 2023 12:29 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
findre
Sep 10, 2015 05:46 PM
prettydaim
Sep 7, 2015 05:16 PM
Bigvettefreak
Sep 6, 2015 04:27 PM
