unable to reprogramme my Engine module Runtime error
Old Jan 5, 2026 | 11:29 AM
OldKarz's Avatar
No matter how long we have been working at something, we can all get blinders on that indicate a reasonable path to fix the problem and stop looking at the whole picture. You are asking people to suggest the fix only using your logic and not coming to a conclusion using all of the information. We have no idea what symptoms were put into SDD or even if all symptoms were actually put in. Were they cherry picked or the whole list put in. I have both Land Rover and Jag and each can throw a fault list that is fixed by something considered 'unrelated' by SDD evaluation.
Old Jan 5, 2026 | 11:42 AM
farm-jag's Avatar
Originally Posted by Don B
With certain earlier versions of SDD, you do not need to connect to Tech Support to get update files. The files are stored in a library on your hard drive. The version I use for X350s is JLR SDD v.131.03. If I recall correctly, I run this package in a Windows XP Pro virtual machine on a Windows 7 laptop. Before I start SDD, I change the laptop date to August 1, 2012 and I disconnect from the Internet.
I have tried later versions of SDD, which are generally faster than 131.03, but they always seem to encounter difficulties of one kind or another, including wanting to connect to Jaguar via the Internet.
This was my only observation also. From the screenshots it looks as though you are attempting to run it natively on Windows 10. I'd say that is a good possibility of being your problem. Generally for STD, I use a virtual machine and only use the max. Version of sdd that was out at the time. The vehicle was relatively new. That's all you need.
Old Jan 5, 2026 | 02:33 PM
Glenncfc's Avatar
As I wrote earleor i am waiting for my programmer to check all the suggestions From Don's help next weeked, I'm good with that for now.
Wilyum
May 9, 2023 09:46 AM
ttwotees
Nov 24, 2010 03:23 PM
