Upper wishbone/ control arm ball joint seal
Had to Jack up car today and the rubber seal on the ball joint spilt and leaked grease. Joint does not seem to have any play in it.
New arms seem to be available but have to remove strut and the arms are expensive.
Any one have any suggestion to replace or seal the joint?
http://www.balljointboots.co.uk/ball-joint-boots.html
Ball Joint Boots
How to measure
From what I see, you normally have to buy a pair or a pack of several.
Yes, you go on-line and buy a new ball joint boot. You have to measure the one that is split, of course, to order the right size.
Ball Joint Boots
How to measure
Ball Joint Boots
How to measure
chatmanx
Sep 11, 2015 07:17 PM
