Urgent! - No start
Hey guys,
I'm in a rut with my 05 XJ8 Vanden Plas- 30k miles
Ok, so when you start the car, you can see the gauge needles climb, hear 2 ignition "ticks," and a belt turning. You can also hear a brief electrical hum when you put it into Accessory. However, after the 2nd tick, the engine/starter dies out. I've tried changing the fuel filter and adding injector cleaner to no avail. The headlights seem to flicker when you try to start the car, too- didnt happen before. I really need some advice!
Thanks a million
Thanks a million
Matt,
I've moved your post to the XJ tech section so you'll get expert help.
Clean the battery connections and the bolt attaching the earth strap to the body by the battery.
Do all the dash lights go out when you get your 'click'?
