Urgent! - No start
Old Feb 3, 2013 | 01:23 AM
CaliforniaMatt's Avatar
Default Urgent! - No start
Hey guys,
I'm in a rut with my 05 XJ8 Vanden Plas- 30k miles
Ok, so when you start the car, you can see the gauge needles climb, hear 2 ignition "ticks," and a belt turning. You can also hear a brief electrical hum when you put it into Accessory. However, after the 2nd tick, the engine/starter dies out. I've tried changing the fuel filter and adding injector cleaner to no avail. The headlights seem to flicker when you try to start the car, too- didnt happen before. I really need some advice!
Thanks a million
Old Feb 3, 2013 | 03:19 AM
My best guess for what its worth.
The battery is not up to snuff, and/or the battery cable connections. The +ve connector and "master fuse" thingy in that connector is also high on my list.
Old Feb 3, 2013 | 03:25 AM
steveinfrance's Avatar
Matt,
I've moved your post to the XJ tech section so you'll get expert help.
Clean the battery connections and the bolt attaching the earth strap to the body by the battery.
Do all the dash lights go out when you get your 'click'?
Old Feb 4, 2013 | 10:48 PM
I have clean battery terminals and the cable is good. The battery has never been replaced. When the click happens, nothing happens to the electrics :\
Old Feb 4, 2013 | 11:39 PM
JRP's Avatar
JRP
Sounds like a classic symptom of needing a new battery especially considering it original.
Old Feb 5, 2013 | 12:36 AM
djdex's Avatar
Yep agree with the guys - classic battery symptoms, try a jump start from a known good one/car, if it springs into life you need a new battery.
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Bones
Sep 8, 2015 08:34 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
