Vibrataion
Old Jul 12, 2017 | 04:17 PM
JagsteRJX's Avatar
Default Vibration
I've had this vibration for a month now. Originally, it started out as a noise like a pita patta on the road. I thought it was my exhaust, as I had just had it modified. I did a tire rotation, after the rotation there was a vibration/grinding coming through the the steering wheel and accelerator when turning right on bends or on/off ramps at speed. So I took it into Jaguar to diagnose with some other issues, they said the wheel was out of balance and they quoted $100 to balance the wheels (which I laughed at).
I took the car to a wheel specialist to fix the rear rim, as it was loosing pressure. The wheel specialist fixed two more rims and balanced all 4 tires for $25. So, I thought the vibration would be fixed, so after getting the car back the vibration was still there. The wheel specialist said the vibration could be caused because the rims had bends in them and could cause high points once the rims have been fixed. He said it would take the same miles (15000) as it took to create the vibration to wear the tires back to round again.
So, I had an indy look at it and he said the front left wheel hub needs replacing, he put ears on it when on the hoist and said he could hear the hub had a flat spot it. When driving home from the indy the vibration is happening on the straight and when turning to the left now, also it appears to be getting worse.
Who to believe? Any thoughts or input on this one.
Old Jul 12, 2017 | 04:26 PM
jackra_1's Avatar
I am inclined to think it is the bearing especially since you mention "grinding".
Old Jul 12, 2017 | 05:23 PM
meirion1's Avatar
You can buy a hub for not a lot of money but the four nuts that hold the hub on can
be very difficult to remove.
Old Jul 13, 2017 | 01:24 PM
hisport's Avatar
Have the indie who diagnosed the wheel brg fix your car
Have him evaluate your wheels/tires as well. The $25 tire guy is v incompetent
Buy the indie a bottle of scotch this xmas, and then stick with him
Old Jul 13, 2017 | 08:46 PM
JagsteRJX's Avatar
Unfortunately, the indie doesn't do tires and balancing. The wheel guy doesn't do mechanical or suspension. Jaguar Cincinnati has no ideal about anything, except how to over charge. This is my first time using the indie, so no real experience using him. Tire discounters will do a free evaluation of the tires and suspension, but that's probably bringing too many into the equation.
Anyone know of a good quality replacement hub brand/s? Rock auto has Moog in stock.
Old Jul 13, 2017 | 10:25 PM
Qvhk's Avatar
Vibration from wheels normally hit the strongest when car speed reaches 60 mph, and if you hear grinding noise particularly when cornering it could be the wheel bearings wearing out. You can jack up the car with wheels hanging in the air and moving them at all angles and if you feel any free play, then you catch the culprit. However, engine mounts (two front) and the transmission mount (one back at the end of the gearbox) can also be the source of vibration. Would suggest you inspect your car carefully from down under to identify all suspects and then decide if this is the job for your indie or others.
Old Jul 18, 2017 | 02:41 PM
Peter Svoboda's Avatar
If it is a grinding noise coming through the steering while turning left or right now, I would need eyes to verify but it sounds like a bad wheel bearing and possibly also your hub. I am also located in the Cincinnati area if I can be of any assistance.
Old Jul 18, 2017 | 10:14 PM
Panelhead's Avatar
Default Detroit Axle Hubs
I do not see info on your vehicle, but Detroit Axle has a pair of hubs and bearings on ebay for 82.99 and free shipping. Includes the ABS sensor. This is almost free, they are heavy.
I have a set on my XJR. Have been working fine. These show to fit 2004 - 2008 models.
Old Jul 19, 2017 | 03:11 PM
The more I think about it, the more unlikely it sounds to be that you would have both your wheel bearings go out at the same time. I might check steering linkage, roll bar linkage.. does not sound good if it is traveling from one side to then both sides. can you post pictures?
Old Jul 20, 2017 | 07:32 PM
JagsteRJX's Avatar
I have a new Moog hub from Rock auto, I'm taking the car to the indie to replace the driver's side hub on Tuesday. Hopefully the indie is correct and the vibration will be fixed.
Old Jul 26, 2017 | 08:43 AM
JagsteRJX's Avatar
Today was the day the indie installed the new Moog hub, NO MORE VIIIBRAAATIIIOONNNNNN
I'll be talking with the service manager of Jaguar about their misdiagnosis too.
