Wet Carpet on Driver's Side, 2005 XJ8L
Old Nov 17, 2015 | 03:22 PM
jaghunter's Avatar
Default Wet Carpet on Driver's Side, 2005 XJ8L
Just recently, I have noticed the front driver's side carpet wet after a rain shower. The car is parked. I have water pooled on top of the rubber floor mat and the carpet underneath is wet. I have checked the drain plugs on the left and right side under the windshield plenum and they are clear and draining properly. The front passenger side carpet is dry. Any idea where this water intrusion is coming from on the front diver's side?
Old Nov 17, 2015 | 04:53 PM
Sean W's Avatar
Hi. Give this a look see.Page 3 should address the likely cause.
Old Nov 18, 2015 | 10:18 AM
jaghunter's Avatar
Thank you Sean. This is very, very helpful in narrowing down things. Greatly appreciated.
Old Nov 19, 2015 | 08:57 AM
rhankey's Avatar
Check to see that the sunroof drain lines aren't clogged. There should never be standing water in the sunroof gutter.
wolfhamm
Nov 14, 2021 02:06 PM
CBY335
Mar 9, 2021 09:57 AM
thedugger1
Oct 29, 2015 11:47 AM
joolz
Oct 28, 2015 03:59 PM
Chris Jenkins
Oct 22, 2015 07:15 PM
