What is this vibration!!!!!
Old Feb 25, 2013 | 02:31 PM
jsupstarz's Avatar
Default What is this vibration!!!!!
2004 xjr 200k. No faults.
Ok when the car is in park idles perfect everything smooth, when I put in to drive while brake engaged there is a strong vibration I feel. As I accelerate at low speeds and lower rpms like under 4 k and under 40 mph i feel vibration pretty heave while pressing the gas, it goes away once I take my foot off gas, or just coast like for instance stable speed, it's just the accel part that i feel a heavy vibration like somethings not right, if i floor it or WOT it feels like it's suppose to no weird vibrations. Could this be plugs, fuel filter?? THANKS
Old Feb 25, 2013 | 06:57 PM
cjd's Avatar
cjd
Is the check engine light on? It definitely sounds like an engine miss. If it is it should show a code on the OBD. If there is no light, there still may be a code caused by an intermittent fault.
So, I guess your first step is to check for a code, then we can go from there...
yoiyoi
Dec 19, 2023 12:51 AM
Inspector
Oct 17, 2015 12:51 PM
BathoryFan
Sep 15, 2015 05:04 PM
hen555
Sep 7, 2015 11:13 PM
