Whistle under load
Old Feb 9, 2025 | 08:48 AM
mbwillgrubs's Avatar
Default Whistle under load
I am hearing a whistle when I open the throttle, especially under load. It stops when the car is cruising and is not evident at idle. This would indicate something related to the throttle body or vacuum leak, but I am getting no indications of a leak.
Has anyone experienced this?
Thanks in advance.
Old Feb 10, 2025 | 07:39 AM
I think I know what it is. I worked on the cooling system (radiator, water pump, thermostat housing, valley hose, etc.) and I think I am hearing it bleed steam. It does not make the noise when cold and I even heard it when the engine was off. It also seems like it is less pronounced. We shall see.
Old Feb 10, 2025 | 10:09 AM
Wingrider's Avatar
Check the coolant level, steam is not good!!!!!!!!!!!
Old Feb 12, 2025 | 04:24 PM
I think it was just an object hitting the climate control fan. Just would happen under acceleration. Oh, well. Funny how one talks themselves into things. Thanks for the reply.
sicarumba
May 5, 2026 09:14 AM
RaceDiagnostics
Feb 27, 2019 05:58 PM
mariasm
Nov 5, 2016 05:44 PM
Cambo
General Tech Help
Apr 19, 2014 10:16 AM
usedjaggy
Apr 11, 2010 01:38 AM
