Bi xenon
Old Jan 13, 2025 | 08:25 AM
Matti Pullinen's Avatar
Default Bi xenon
Problem is that there was dipped and main xenon. Both main lights stopped changing to main beam at the same time. Halogen main light is working. Fuse and relay are ok.
where is driver for xenon flap? There is no wiring fir it in diagram.
What can be problem?
Old Jan 13, 2025 | 01:26 PM
Pete M's Avatar
Hi Matti,
See my other answer. What year is your car. It's always useful to put the car's details in your signature.
Bi-Xenon with HID having both high and low beams seems to have been only in certain markets, and I think, was changed to HID low beam only at some point in production. My 2008 Ex-Japan car has only low beam HID.
So some early cars in some markets may have had Bi-Xenon, but I think they were in a minority.
My car has the Valeo low beam only HID units and they are very hard to find Bi-Xenon units that will fit in the space.
In the meantime, I have fitted HID compatible LEDs as a trial.
Pete M
Old Jan 13, 2025 | 10:44 PM
Default X350 2007
Hi,
my car has bi xenon system. It used to work but now the flap does not move. I need info where solenoid gets info/power. Can not find info wiring diagram.
Old Jan 14, 2025 | 03:24 PM
Pete M's Avatar
Originally Posted by Matti Pullinen
Hi,
Hi Matti,
It looks like my reply to your other post went missing, so here is the diagram again.
Pete M
Headlight circuit for HID Bi-Xenon cars.
Old Jan 14, 2025 | 08:11 PM
Thanks,
what is this connection 38?
Matti
Old Jan 15, 2025 | 03:14 AM
Thomas-S.'s Avatar
Hi Matti,
look here:
Maybe I have overlookeb it, but I have not seen what car you exactly have. Could you please include the details (engine, month/year of the car), then we can search for the correct diagram?
Best regards,
Thomas
Old Jan 15, 2025 | 03:24 AM
Car is x350, 3.5 liter v8, 2006.
I have one diagram, but there is nothing about managing this flap info xenon.
Can It be driven by can network?
this is amazing Forum- nice People helping.
Matti
Old Jan 15, 2025 | 03:46 AM
Thomas-S.'s Avatar
Hi Matti,
I have tried to attach the electrical guide for the MY2006, hopefully it worked. If yes, you at least have the comprehensive explanations of all the symbols, etc.
If you look to Figure 08.1, in the headlight clusters there is a small part called "dip". Maybe that's the flap. Unfortunately, I could not find anything more specific.
Best regards,
Thomas
File Type: pdf
Old Jan 15, 2025 | 08:57 AM
Hello
I have checked this diagram. Nothin according to move the flap.
Weird situation.
Old Jan 15, 2025 | 12:38 PM
Pete M's Avatar
I think the oval object to the right of the headlamp levelling module is the solenoid. Bulbs are denoted by a circle with an X inside.
Pete M
Old Feb 12, 2025 | 11:00 PM
Default Problem solved
Originally Posted by Thomas-S.
Hi Matti,
look here:
Best regards,
Thomas
I removed headlights. Power to bixenon flap is directly taken from main beam inside headlight unit.
Majog
20
Jan 15, 2023 08:22 AM
jagent
Jun 5, 2022 02:18 PM
DrVertigo
Nov 20, 2018 08:24 AM
shawnjglen
Jan 20, 2012 05:02 PM
satwarez
Jan 13, 2011 08:31 AM
