Will '04 Brembos fit '06 XJR?
Old Jan 11, 2014 | 12:21 PM
djlimer's Avatar
Default Will '04 Brembos fit '06 XJR?
Hey all.
After searching for quite a while, I finally found the right deal for an '06 XJR and picked it up last week. Thus far, I couldn't be happier with the car and the deal that I got on it... except for one little thing. Of course '06 was the year where Jaguar cheaped out and didn't put brembo brakes on the XJR. So, my question is, if I find a solid used set of 04 or 05 XJR Brembos can those bolt on to an 06 without major mods? If it does take modifications how complex are they.
Thanks for any suggestions you might have.
D.J.
Old Jan 12, 2014 | 07:38 AM
ryejag's Avatar
DJ
Wow, its one thing to "decontent" a later model car by taking out some sound insulation or trim part, but the brakes! I am surprised and curious what others have to say about this. I have no idea about retrofitting.
RyeJag aka '04 model with Brembo brakes
Old Jan 12, 2014 | 12:56 PM
banjobill's Avatar
Hi,
I prefer to have the Brembo option, to make the conversion you will need the Brembo car front vertical link arms and possibly the rear hubs, not a cheap conversion.
Good luck.
Old Jan 12, 2014 | 12:59 PM
rhankey's Avatar
I believe the hand brake works differently too.
Old Jan 12, 2014 | 03:05 PM
Fraser Mitchell's Avatar
Brembo rear brakes use a separate handbrake caliper. Brembo also cost a lot more in pads and discs than standard.
Old Jan 14, 2014 | 04:11 AM
PigletJohn's Avatar
are the later ones actually worse? What is the disc size difference?
dsnyder586
Dec 29, 2024 07:39 PM
Tinyxjr2015
Sep 14, 2015 07:50 PM
metalmarty
Sep 11, 2015 07:05 AM
philwarner
Sep 6, 2015 11:10 PM
AL NZ
Sep 4, 2015 08:39 PM
