Wiper Replacemnt
Old Mar 8, 2017 | 08:59 PM
martin49315's Avatar
Default Wiper Replacemnt
Jaguar X350 2007.
Is there an easy way to replace the wiper blades on this model?
The arm does not lift all the way up like it would do on most cars due to fouling on the edge of the bonnet.
Is it possible to stop the wipers at vertical to allow the blades to be changed easily - without removing tha battery that is!!
Seems to me as though the may be a hack for this that the dealer would use when it is time to replace wipers as it seems a bit of a pain of a job from what I have seen so far.... Don't really want to go down the road of removing the wiper arms either but that is what I am considering at the moment!
Cheers...............
Old Mar 8, 2017 | 09:44 PM
Mark in Maine's Avatar
Open the bonnet. Put a towel under the wiper before you remove it (wont scratch the glass.) Most of us just replace the rubber blade. Slide out, slide in.
Old Mar 9, 2017 | 05:31 PM
Had a play with these at work this evening and they actually come off fine - a bit of a fiddle but they do slide off in exactly the same way as any other blade, rather than being vertical you just have to slide the wiper along the line of the windscreen once you have released the hook from the clip on the blade and off they come!
I bought some BOSCH Aero blades that have the washer nozzle already attached from Euro Car Parts (UK) for approx. £25.00 an they have done the job spot on!
Old Mar 9, 2017 | 11:22 PM
You guys across the pond are very lucky to be able to purchase the Aero blades locally. We over here are not so lucky.
Old Mar 11, 2017 | 04:52 PM
Rancheroguy's Avatar
I just asked the guy at AutoZone to do it for me. (Sometimes getting old pays off) He to just replaced the blades, cost 1/2 the price of new assembly's about $8.00.
Old Mar 11, 2017 | 06:05 PM
Dr John's Avatar
Try this. Turn the ignition to the second position- just before starting the car - and pull the wiper lever once towards you like you were going to wipe the windshield once. It should wipe half way and stop. This gives you enough clearance to lift the arm and remove the wiper.
Old Mar 11, 2017 | 10:57 PM
Doesn't the wiper still return to the park position? never tried this.
Old Mar 19, 2017 | 04:43 PM
ejhc11's Avatar
Just did mine this weekend. Changed the wiper inserts, didn't even have to remove wipers. Was real easy too!
See video
Don't remove wipers and make sure to buy the correct wiper inserts.
5 min per side.
Old Mar 22, 2017 | 06:10 PM
Dr John's Avatar
I read how to park the wipers from a manual but my car doesn't do it. Sorry for the mis-information Mark
Old Mar 27, 2017 | 08:17 PM
Dr John's Avatar
I saw this and it works on some xj's
https://www.carcarekiosk.com/video/2...e_wiper_blades
Old Mar 27, 2017 | 09:01 PM
I'll try this park option out tuesday, and report back. I think they might have left out the part about turning the key off at mid point.
Old Mar 28, 2017 | 05:10 PM
ejhc11's Avatar
Mark,
No need to park the wipers. Just squeeze the wiper ends like in the video with a slight lift of them where they are. They slide right out and easily back in without removal or parking them. Less than 2min out and 3min in - done!
Old Mar 28, 2017 | 06:08 PM
I've changed the blades many times without "parking the wiper arm. Thats because you cannot park the arm mid point on a X350. The last post doesn't park them either. If changing the whole blade assy, you have to open the bonnet to get the arms up high enough to remove the whole wiper assy.
Old Apr 1, 2017 | 10:47 AM
Sundalo's Avatar
eBay has them
eBay has them
Old Apr 1, 2017 | 05:29 PM
Partick the Cat's Avatar
Google 'Eurocarparts'. They are a UK outfit and stock Bosch replacement wiper blades, including the AR608S, and they do ship stuff abroad. Doesn't cost anything to have a look at their webpage.
(No connection other than being a satisfied customer).
