x350, 2006 xj8 monitor not reporting
Old Sep 29, 2019 | 08:34 PM
car-nut1's Avatar
Default x350, 2006 xj8 monitor not reporting
So the cat is 13 yrs old. Had a leaky front air shock. Replaced and all is well. Unplugged the battery while replacing- as many recommend.
Now 300 miles later car rides perfect, but its time for inspection and there are two monitors not reporting.
1. secondary air system.
2. oxygen sensor monitor.
all others are fine. what I cant figure out is these are not listed by jag as part of the 7 monitors in my car- those 7 are fine and reporting. because of that I cant figure any info about the drive cycle for those. any info would be appreciated.
thx
car-nut1
Old Sep 30, 2019 | 03:24 AM
JagV8's Avatar
I think you're looking at earlier docs. Look for Jaguar Denso ones.
I think they're in the large file area / the net generally.
Old Sep 30, 2019 | 02:32 PM
car-nut1's Avatar
not being lazy but I can't find anything more. I looked through the shop manual for x350 and I really don't find a cycle for those monitors- secondary air, and oxygen sensor (not the heater circuit that one is closed). Any info is appreciated if you have a link. thx
Old Sep 30, 2019 | 11:22 PM
car-nut1's Avatar
Default pics of code reader
see pics of code reader...the same issue was brought up at inspection so unlikely that the reader is bad
bottom line two monitors that I can't find anything about are not reporting and I don't know what their drive cycle is. thx
Old Oct 2, 2019 | 06:16 AM
JagV8's Avatar
Maybe the shop manual you have is before those items were added.
Old Oct 2, 2019 | 04:30 PM
car-nut1's Avatar
its possible. I'm trying to avoid the dealer. I will look at more recent xj just in case...do you have any ideas how to close these? I just need 1 more to report
Old Oct 2, 2019 | 05:12 PM
JagV8's Avatar
Yes, I'd hunt for / refer to the docs in the places I mentioned. Pretty sure they are there but I don't have the same issues.
Old Oct 2, 2019 | 05:14 PM
car-nut1's Avatar
Can you send me a link if possible, I couldn't find where you mentioned...still trying to navigate this site. thx
Old Oct 2, 2019 | 06:59 PM
Six Rotors's Avatar
According to the 2006 XJ Technical Guide there is a secondary air injection system as part of the emission controls. You maybe able to trouble shoot it from the attached.
File Type: pdf
Old Oct 2, 2019 | 08:59 PM
Wingrider's Avatar
Sometimes the emissions systems take a long time to clear.
How far down do you let the fuel level drop?
Keeping it too full can be an issue, or so i've read.
Old Oct 2, 2019 | 10:07 PM
abonano's Avatar
On this point keep your tank between 1/4 and no higher than 3/4 tank.
Old Oct 3, 2019 | 02:10 AM
JagV8's Avatar
https://lmgtfy.com/?q=jaguar+xj+dens...ir+obd+monitor
GunnerCG20
Jun 28, 2019 05:04 PM
Robert442
Jul 2, 2015 08:41 PM
golfjag1
Jul 23, 2013 06:59 AM
Flyfishing
Dec 11, 2012 05:45 PM
