X350 Alt smart charge feature
Old Jun 6, 2019 | 09:14 AM
Mark in Maine's Avatar
Default X350 Alt smart charge feature
Can anyone confirm if the X350's alt, is a smart charge system? Only getting 13.6 with new alt and new battery while running. If not, would a small short to ground be involved? Will do a full parasitic draw test this week. Thats a lot of fuses.
Old Jun 6, 2019 | 10:29 PM
JRT-MG's Avatar
The excerpt I have from the shop manual on the alternator description:
"Vehicles fitted with 3.5L or 4.2L engine (SC1 generator)
The battery charging voltage is determined by the temperature of the generator. In cold conditions, starting the vehicle from cold the battery voltage will be between 14.2 volts and 15.1 volts and will reduce as the engine warms up. In hot conditions starting the vehicle when the engine is already warm the battery voltage will be between 13.5 volts and 14.3 volts ."
Dave
Old Jun 7, 2019 | 07:44 AM
Wingrider's Avatar
With a new fully charged battery, 13.6 after recovering from the initial draw to start, sounds about right.
Old Jun 7, 2019 | 11:27 AM
mikebaker3's Avatar
Measure running volts with a multimeter, which should give an idea of accuracy.
Old Jun 8, 2019 | 08:36 PM
ChrisMills's Avatar
X358 is a smart charge system, ~14.6v switches to ~13.6v after exactly 5mins.
I don't know if the X350 is different, but check in the first 5mins.
Old Jun 8, 2019 | 11:40 PM
Don B's Avatar
Here's the more extended explanation of the charging system explanation from the X350 Technical Introduction. The charging system is designed for the original Varta calcium-silver technology batteries:
Cheers,
Don
labans
Sep 20, 2021 08:56 PM
car5car
Sep 14, 2016 08:41 AM
twinstacks
Aug 18, 2015 04:13 PM
Frenchy
May 19, 2015 09:47 AM
scoita
Jun 7, 2013 06:44 AM
