X350 door panel screws!
Old Dec 3, 2015 | 12:04 PM
brittunculus's Avatar
Default X350 door panel screws!
Have got an annoying minor rattle in driver's door. Turns out that one of the 2 screws is missing! Took the other one out. Is a black cross head screw 1.5" or 4cm long. Not too sure what to order up! Does anyone know the # / type please?
Old Nov 20, 2023 | 03:38 PM
Jaroslav Záruba's Avatar
For future seekers, I believe it could be C2C7733
Old Nov 21, 2023 | 11:28 AM
wfooshee's Avatar
I think he means the screws at the bottom of the door panel, not the armrest screws. I haven't found a diagram that lists the hardware, just the panel.
Old Nov 21, 2023 | 02:35 PM
I admit there's some room for mistake (i.e. I might be wrong), but here's why I think he meant the screw that goes through the armrest and holds the panel onto the door itself (and not the screw at the bottom of the panel)
- it's the only type of screw (on SWB) of which there are two pieces ("Turns out that one of the 2 screws is missing!")
- it is the only 4 cm long screw on the panel, it is black with a cross head ("Is a black cross head screw 1.5" or 4cm long.")
There are indeed two pieces of plastic scrivets on LWB, but those are not 4cm long.
And here's why I believe C2C7733 is the label of the screw that goes through the armrest and holds the panel onto the door itself
- there's no other similar (let alone self-tapping) screw on the rest of the relevant diagrams:
GENUINE DOOR CASING-FRONT FOR JAGUAR XJ 2003 - 2009 (FROM G00442 TO H32732) CLASSIC
GENUINE DOOR CASING-REAR FOR JAGUAR XJ 2003 - 2009 (FROM G00442 TO H32732) CLASSIC
Old Nov 21, 2023 | 04:10 PM
wfooshee's Avatar
That may be my mistake... I was thinking the door panels had screws at the bottom that went up from underneath, but I may be thinking of a previous car.
Old Nov 22, 2023 | 09:24 AM
wfooshee's Avatar
Nope... there are screws at the bottom of the door panels, one in the front doors and two in the rear. (Mine is LWB, so the SWB might not have 2 in the back, I don't know.) I don't see the screws in any parts list, though. Also, since he said one of the two is missing, it's probably not these, since the driver's door only has one...
Old Nov 22, 2023 | 09:42 AM
Yep, that's what I meant here:
Originally Posted by Jaroslav Záruba
There are indeed two pieces of plastic scrivets on LWB, but those are not 4cm long. http://youtu.be/bgv866p6IX4?t=115
The diagram (and the author of the video above) refer to them as "scrivets"
Old Nov 25, 2023 | 02:50 PM
Thomas-S.'s Avatar
Quote
Unquote
It's a combination of a rivet that gets fixed in place with the screw, therefore the name "scrivet". If I remember correctly, they are made of plastic.
Best regards,
Thomas
Old Nov 27, 2023 | 12:34 PM
redrover41's Avatar
Here in the US most auto parts stores carry the 'scrivets' in many sizes but not always the one we need. It may seem a no-brainer but taking the OEM part to the store may help find an exact match or a 'close enough' match. I bought a box of mixed scrivets when I tackled a couple of cooling system 2-3 years back. OEMs had been gooched and would not hold various panels in place. I'll roll the dice here and state I probably got the box from eBay or Amazon.
ram_g
Yesterday 11:20 PM
Valerie Stabenow
Mar 7, 2023 09:47 PM
Texasbill
Dec 1, 2018 07:30 AM
mikelish24
Jan 29, 2014 03:48 PM
bill586
Sep 2, 2013 11:10 PM
