xj8 bonnet release problem
Old Nov 3, 2008 | 09:18 AM
Peter.H's Avatar
Default RE: xj8 bonnet release problem
Assuming your car is right hand drive, the bonnet release lever on the XJ8 (mine's 1998) is on the driver's side, not passenger side! maybe you've been pulling something else! Try looking at the drivers side for the lever which might be OK.
Old Nov 3, 2008 | 03:15 PM
Brutal's Avatar
the handle is plastic(what else) and you probobly broke 1 of the cable attachments in the handle(there are 2). buy a new hande and remove the 2 10mm nuts and replace the handle, when you get the hood...uh excuse me, bonnet open lube the latches well.....
Old Nov 3, 2008 | 04:31 PM
Brutal's Avatar
if the handle is broken where the little METAL ***** GO INTO THE HANDLE IS WHERE THEY BREAK. if you take the handle off you can grab the ***** with pliers and pull alot harder than the handle and get it to release.(at least Ive always been able too) Then you can lube the latches
Old Aug 27, 2012 | 07:29 PM
Vector's Avatar
Originally Posted by fbrady
Newly aquired;stupidly didnt try bonnet release before purchase[:@]
Are you saying that you did not even look at the engine of the car before you purchased it????
Vector
Old Aug 27, 2012 | 07:48 PM
Gus's Avatar
Gus
I think that is what he said but that was in 2008 a long time ago.
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
jdzubas
Oct 4, 2015 09:14 AM
uncheel
Sep 5, 2015 01:34 PM
Jaguar Forums Editor
Jaguar Press release
Sep 3, 2015 09:38 AM
