XJ8L - Changing Air Con default status
Old Mar 22, 2023 | 08:39 PM
Rufus T. Firefly's Avatar
Default XJ8L - Changing Air Con default status
On my 2007 XJ8L, the A/C defaults to being ON with engine start.
Is there a way to change this to defaulting to OFF?
Mike
Tucson, AZ
Old Mar 22, 2023 | 11:40 PM
paulz67's Avatar
Don't know about non-navigation cars, but in nav-equipped/touchscreen cars, hit the "climate" button to the left of the screen, then touch the "AC button" to turn it off/on (on = red box around the 'button"). Hitting the "Auto" button on the main button cluster will turn the compressor back on, as well.
Paul
Old Mar 24, 2023 | 08:49 AM
wfooshee's Avatar
My 2007, no touch-screen, remembers the last state. If it was off at shutdown, it's off at next startup. I never use the "Auto" setting.
Old Mar 24, 2023 | 09:29 AM
mhamilton's Avatar
Same as previous replies, my car always remembers the last state of the HVAC controls. Exception is if the battery has been disconnected for a long time. It's possible your HVAC unit is losing its Keep Alive Memory... The schematics show 2 ignition switched powers and no constant power to HVAC module, so it seems like your module may be faulty internally.
Old Mar 24, 2023 | 01:39 PM
wfooshee's Avatar
Correction to my post: On mine, it does return to AC on if the interior has warmed up from being out in the sun, even if it's not on Auto. It probably compares the temperature set as desired temp with what it sees on power-up.
Old Mar 24, 2023 | 08:15 PM
Mine is always defaulting to ON regardless of last state or current ambient temperature.
George05
Mar 29, 2022 12:03 AM
JonWat
Jun 3, 2021 07:56 PM
gtunstal
May 4, 2018 08:09 PM
loulizjag
Jun 12, 2015 09:54 AM
Timmah!
May 21, 2015 11:57 AM
