XJ8L expansion tank leakage
Hello all,
This is regarding my recent issues with the coolant leakage. I was enjoying driving through smoky mountains when I received an engine error for the reduced power. When I switched off and on the car, the error vanished for ~20 mins and came back. I checked the codes:
P0116: Engine coolant temperature circuit range/ performance problem
P1260: Security input
P1582: Flight recorder data is stored. (Engine stall?)
I noticed that the coolant level was below suggested level which might have introduced the air in the system causing this high temperature alert and that air bubble traveling through system at a regular interval. I added an extra coolant and was able to remove codes except P1582.
However, I still sometimes smell the coolant leak in the cabin and I can see some leak marks on the expansion tank from the cap thread. Is system under too much pressure? Is there any air bleeding procedure that I need to follow? The heater is working.
My previous post on the XJ8L expansion tank leakage : https://www.jaguarforums.com/forum/x...eakage-198716/
Thanks in advance for your help.
An air bubble is unlikely to cause excessive pressure in the system.
IF there is excessive pressure in the system then it could be where pressure is applied from an external source through a leak into the system and I know of only two such cases. A blown headgasket or a leak in the transmission cooler inside the radiator if you car has that cooler inside the radiator.
Is the coolant in the reservoir "clean" looking?
Does oli on the dipstick look clean? Also on the underside of the oil filler cap does any oil residue look contaminated i.e a milky look?
Any excessive "water" coming out the exhausts when running?
P1582 EDR (Engine Data Recorder) can only be accessed and cleared by going into the 'SETUP AND CONFIG' tab to Special Applications.
You can read and clear the 37 frames of data in either or both A storage or B storage sectors. (whatever has the DATA storage)
Otherwise just ignore.
bob
bob
The coolant header tank is well known for leaks after a few years. Main location is where the small-bore tube enters at the top.The securing nipple cracks and eventually falls off, but well before then, the leak will be noticeable. However, leaks also occur elsewhere too like water pump and also, for supercharged cars, the hose running in the "valley" between the cylinder banks.
There is a similar 'Valley Hose' on Normally Aspirated cars as well. Like the SC cars, if this leaks, the coolant runs down the back of the engine.
(See Michael Hamilton's post): https://www.jaguarforums.com/forum/x...on-s-c-149873/
I checked the coolant in the expansion tank, clear. Also, oil on dipstick and oil filler cap is good. The coolant level remained at the fill level for last 5 days so looks like there is no big coolant leak.
sbxt
Feb 8, 2008 11:50 AM
