XJR brakes on XJ6?
Old Apr 30, 2018 | 04:59 PM
a04054's Avatar
Default XJR brakes on XJ6?
Hi.
Looking to upgrade my '03 XJ6 with XJR brakes - mainly beacause of the nice look of the R calipers/ventilated discs..
Will the XJR calipers and discs fit the XJ6 without modifications?
Regards
Old Apr 30, 2018 | 05:03 PM
abonano's Avatar
Probably not, unfortunately.
Old Apr 30, 2018 | 05:32 PM
a04054's Avatar
That's "probably not" as in "definitely not" - right?
Regards
Old Apr 30, 2018 | 07:48 PM
abonano's Avatar
Regards
[/QUOTE]
Yep, meant definitely not...sorry bud.
I dont think the XJR brakes are comparable on the X308 platform.
Old May 1, 2018 | 01:14 AM
-Greg-'s Avatar
Theoretically, that should work (if both are X350), but you will need to change rotors, calipers and the item that the caliper is bolted on. Generally - whole assembly. The hub size is identical to my knowledge (although might be mistaken).
Old May 1, 2018 | 02:16 PM
Fraser Mitchell's Avatar
If the 2003 car is an X350, it is likely the XJR brakes will fit, but don't forget the road wheel size. The XJR brakes will probably only fit with 18" upwards, maybe even 19".
Old May 1, 2018 | 05:45 PM
meirion1's Avatar
Brembo brakes can be problematic you might want to research that first.
Old May 1, 2018 | 05:54 PM
Cambo's Avatar
The Brembos need a different vertical link / hub carrier, the caliper mounting is not the same.
The Teeves from a 2006MY will bolt up on the front.
The rear Brembos will be a massive undertaking as there are a lot of different parts needed.
Old May 9, 2018 | 09:33 AM
Dan R's Avatar
Get some red caliper covers. That will cover the appearance angle. Might even keep some dust of the wheels.
Old May 9, 2018 | 09:39 AM
Dan R's Avatar
G
Old May 9, 2018 | 03:41 PM
xdave's Avatar
I retrofitted the post-2006 X350 XJR brakes to my 2004 3.0 XJ6. Those are the non-Brembo ones that are still used on the current X351 XJ and some others like the XF. You can buy them OEM in unfinished, red, black and silver, or paint them (I painted mine quartz grey to match the car). The calipers were a direct swap, but you will also need new heat shields and brake hoses as the port position changes. You should also replace the caliper fixing bolts rather than reuse them.
My reason for changing them was because driving alongside my XJR and X351 I was always annoyed at how badly the XJ6 stopped in comparison. It wasn't dangerous; just a bit unnerving when you are used to stronger braking. The consumables were also cheaper last time I checked as they are still current parts.
scottw
Feb 4, 2025 07:33 PM
mikchek
May 8, 2019 11:38 AM
malx
Nov 27, 2015 06:27 AM
alabbasi
Nov 21, 2013 10:40 PM
jimlombardi
Nov 6, 2012 11:30 AM
