XJR Gear Shifter Knob
Old Feb 1, 2020 | 07:29 PM
abonano's Avatar
Default XJR Gear Shifter Knob
Hi everyone,
Went to swap out my XJR gear shifter knob from another used shifter assembly I purchased on the cheap ages ago.
Well, should've left the knob on the donor shifter assembly as it is now in my car.
Had to swap out the analog clock on dash. It was malfunctioning (not keeping time)
One of the screws went into the shifter assembly. When looking in there with my flashlight I found the screw but also part of the grey plastic piece that the shifter shaft sits on.
Back to the knob.
Do not attempt to remove. Jaguar used red loctite on the knob. Wound up having to epoxy the metal shaft back into the knob after getting it off the shifter.
Ideally your supposed to spin back the bottom metal piece and spin the knob off.
Not like the wood knob. The XJR knob will just spin and spin on the metal shaft. You literally have to pull the knob off...
You heard it here first.
But if someone is looking for a XJR knob - I now have one... all cleaned up!
Old Feb 2, 2020 | 11:22 AM
Wingrider's Avatar
Looks like i will not look into replacing mine, it has a couple small cracks in it.
Have not given it much thought, (good thing) been kept busy putting more important things right.
Old Feb 2, 2020 | 11:27 AM
abonano's Avatar
I was not planning to swap it over either but the shifter unit I purchased had a near damn perfect knob.
I said "why not"... there was not much on the net about it either.
Oh well..
Old Oct 25, 2024 | 08:40 AM
Excalibur2012's Avatar
Why not just go full bore ! Sell the Jag & get yourself a Camero with a Hurst Shifter.
Now...that's class !
Old Oct 25, 2024 | 03:25 PM
Wingrider's Avatar
W T F
Old Oct 26, 2024 | 07:39 AM
Bottom line ! That crap never improves anything.
Old Oct 26, 2024 | 11:32 AM
Thermite's Avatar
Now...that's crass!
Fixed the spelling error for ya.
Old Oct 28, 2024 | 09:45 AM
The only spelling error was Camaro !
Old Oct 28, 2024 | 04:34 PM
Thermite's Avatar
Not a native Spanish speaker, here, but go ogle finds anecdotal evidence that at least one jorno 'back in the day' claimed the original meaning of 'camaro' was "loose bowels".
Fitting for a muscle car meant to s*t n' git, braking, negotiating curves or corners, 'optional', yah?
So the motive may be questionable, but the spelling seems spot on.
Old Oct 29, 2024 | 06:38 AM
Smile
emaychbe
Sep 8, 2017 11:29 AM
3timejag
Jul 14, 2017 09:31 AM
BlacXJRcat
Oct 22, 2016 08:59 AM
mvivio
Apr 30, 2016 08:25 AM
BrentGardner
May 18, 2015 08:31 AM
