ZF Mechatronic Sealing Adapter Differences Help!
Old Aug 19, 2024 | 02:59 PM
CyanJag's Avatar
Default ZF Mechatronic Sealing Adapter Differences Help!
Currently have the Mechatronic dropped in my driveway thinking this was going to be easy...
I've read there are differences in height... but I seem to have one with the correct height yet another difference.
In the middle of the new part there is a boss sticking out that interferes with the transmission. There is also a little "flag" sticking off the side. But I've seen that on them on other posts.
I'm considering just cutting it off with a utility knife because as far as I can tell.... there are no other differences.
Anyone familiar with these?
I bought the REIN TSK0018 off Amazon which specifically says its compatible. Unfortunately I meant to buy from CTSC but an order was placed on my Amazon when the REIN kit was in my cart... I thought screw it... I'll just use it since it was already delivered. What a mistake...
Old Aug 19, 2024 | 05:25 PM
Big Koshka's Avatar
OK here is from authority in ZF transmissions in US:
https://zftranspart.mypinnaclecart.c...seal-6hp19/21/
https://zftranspart.mypinnaclecart.c...l-6hp26/28/32/
When I did mine transmission seal kit there was no 'luggage tag' on bridge seal. Here what I bought for mine one year ago:
https://www.ebay.com/itm/38529559502...2YEEN3FCZH2BPM
FWIW: the biddger opening is different between old and new on your picture.
Old Aug 19, 2024 | 11:25 PM
CyanJag's Avatar
Originally Posted by Big Koshka
lol if you zoom in on either one of those photos they have the little boss in the middle...
I cut it off with a pair of really sharp flush cutters and sent it... Seems fine. Drove pretty hard for 20 minutes.
On a side note.... it took all of the 6 quarts i had and still needs a little more... Seems to drive and shift all around better. It hasn't given me the transmission fault again yet.
Old Aug 20, 2024 | 11:32 AM
Big Koshka's Avatar
When did similar job on mine. it was acting up for about 10miles but then it was functioning as supposed to.
Some times it has pronounced downshift coming to stop light at high rate if decelleration.
Ken O
Dec 25, 2023 12:29 AM
jaghag00
Feb 14, 2018 01:20 PM
McJag222
Nov 9, 2016 09:43 PM
tc1728
Sep 28, 2012 01:11 PM
moronthethrottle
Apr 30, 2009 04:06 PM
