1995 X300 No Start
Old Apr 23, 2011 | 02:57 PM
colindavies's Avatar
Question 1995 X300 No Start
Parked car up wnet back to it 3 hours later and no start spines over ok.check for spark thats ok then check fuel lines and no fuel.Is there a cut of switch and if so where is it
Old Apr 24, 2011 | 09:17 PM
Gus's Avatar
Gus
I am going to move your post over to the correct venue. Chances of your getting help is better.
Old Apr 25, 2011 | 03:29 AM
Welcome to the forum Colin, I hope you get her going again, Check into the X300 section for tech questions.
Old Apr 25, 2011 | 09:37 AM
aholbro1's Avatar
Many say the fuel pump's done by 100k miles....
Sorry, can't recall where the inertia switch is, but a search might dredge up a location
Old Apr 25, 2011 | 11:16 AM
Welcome to the forum,
Hope you get to the bottom of the problem.
Old Apr 25, 2011 | 06:55 PM
asm54's Avatar
You my want to check the fuel pump relay first, it is located in the fuse box in the trunk/boot.
Old Apr 26, 2011 | 01:50 PM
Default Thanks for help
No Shes not going yet found fuel cut of switch down in the drivers foot well right up in the corner.Fuel pump relay is working when trying to start can hear pump working.Now iv got the heater display saying er when i turn the ignition on and about 10 low beeps.Im looking at a CAR PC DIAGNOSTIC SCANNER FAULT CODE READER ELM 327 OBD on ebay does any know if it will work on mine
Old Apr 26, 2011 | 05:48 PM
aholbro1's Avatar
It will read the Powertrain codes...which should be the pertinent ones for your engine. But chassis codes, ABS and the like...you'll need much more expensive machine for that. I bought an Autel OBDII from Amazon for <$25 and it reads/clears the P codes (I get a recurring P0411 (Secondary air sys) every couple of weeks. A couple of weeks ago I bought the ELM327 bluetooth one hoping to read some real-time data. I'm using it with an Android phone and "Torque" app. It claims 3 different codes instead of what the Autel sees as a P0411. Trouble is, a few months ago..the Autel was in agreement with the Jag WDS...so I think it is the right one. I beleive that is a function of the free app "Torque" rather than the ELM scanner itself, though.
You've checked for fuel at the rail? Then you only need spark....I know several people have reported failed coils but seems like they usually back-feed through the elec. system and other strange stuff as they fail rather than all go at once and result in a no-start.
Old Apr 26, 2011 | 11:52 PM
sparkenzap's Avatar
Does your tach read a signal while you crank?
Old May 5, 2011 | 04:44 AM
Yes it move while cranking
Old May 6, 2011 | 01:19 AM
Have done a OBD scan on the engine and come back all clear. The fuel pump works when you crank over the engine but still no fuel at engine. The thing get me is what are the beep from the car when i turn the ignition on and the "ER" which is display in heater display.I just don't know what to do next
Old May 6, 2011 | 03:02 AM
sparkenzap's Avatar
I suspect the ER in the climate control is a separate issue. A known defect in these cars is the rubber pump discharge hose blowing off the hose barb inside the gas tank . If II understand your post, you have confirmed no fuel at the engine, right? If so, my bet is on the internal hose being off. Archives give a good step by step for fuel pump R/R either here or the XJ8 forum. X-300 and X-308 tank R/R is the same.
In brief, Remove fuel with siphon. Remove push on fuel lines from tank, under the car. (I find it easier to lower rear end assembley for access and then I still use a pipe split lengthwise to push fuel fitting tool into fittings for removal). Folks with smaller hands say they don't need this step! disconnect filler. disconnect harnesses, including taillights, I believe. Unbolt tank and remove. Go in through top. Some folks have cut the rear "tray metal for top tank access, I believe, but this extreme in that R/R the conventional way is no THAT bad!.
Good luck.
Old May 6, 2011 | 05:40 PM
97X300VP's Avatar
Crank position sensor??
Old May 6, 2011 | 09:37 PM
sparkenzap's Avatar
97x399vp
The key to indicate he CKps is probably NOT the culprit is that there is a tach signal while cranking/
aholbro1
Dec 29, 2024 06:46 PM
JimMLiny
Sep 9, 2015 08:13 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
AL NZ
Sep 4, 2015 08:39 PM
d a
Sep 3, 2015 02:34 AM
