1996 X300 codes
Old May 22, 2014 | 08:02 AM
sparkenzap's Avatar
I would not jump to that conclusion YET. Have you access to another scanner from a friend to try? They can be quircky getting set up. Have you got the communication set setup right?
Old May 22, 2014 | 08:21 AM
AllanG's Avatar
Exactly right. Sometimes these units do not automatically find the correct protocol to connect and you have to force them to use it.
The protocol used is ISO9141 (sometimes shown as ISO9141-2)
Old May 22, 2014 | 08:43 AM
Dave2254's Avatar
I just followed the instructions it work ok on my fiat, when plugged into the X300 it says "communicating with viechle" then after a min or so says error couldnt connect with vichle.
What should i try? Sorry im not at all technical
Old May 22, 2014 | 10:12 AM
AllanG's Avatar
Dave, which model of maxi scan did you buy? Also did it come with a manual, should be connection advice in there. If not post the model and I'll look it up.
Old May 22, 2014 | 10:46 AM
Dave2254's Avatar
Hi it was the maxi scan ms309. In the manual it didnt have much about connecting issues
Old May 22, 2014 | 03:28 PM
AllanG's Avatar
Hmmm, it doesn't look like the protocol is configurable. The manual says that if you get a connection error, unplug the unit for 10 secs minimum and then retry. Have you tried that?
If you still can't get it to work, go to a big auto parts shop and see if they can read the code for you. If that doesn't work you probably have a wiring issue from the OBD socket to the ECM or perhaps a bad ECM
Old May 22, 2014 | 04:16 PM
sparkenzap's Avatar
Allan:
I ain't so sure the parts stores read code in England... There seems to be a cottage industry of mobile guys who charge seemingly excessive amounts to read codes!
So Dave- You don't have any mates with an X-300?
Old May 22, 2014 | 05:52 PM
  #28
Dave2254's Avatar
Hi there i dnt know anyone who owns a jag let alone an X300! Im getting quite depressed about it if im honest, havnt heared her running since Febuary! I know it must be something fairly simply as it just stop starting overnight.
Old May 22, 2014 | 06:56 PM
AllanG's Avatar
Allan:
Ross,
My local Halfords in London let me use one on my sister's car free of charge. Don't know if that was a one off or common?
Old Aug 28, 2014 | 02:42 PM
  #30
gr8punkin's Avatar
Dave, I know the last communications were two months ago but I am curious if you got it figured out? and if so what was the culprit?
Also I'm would like to ask the more knowledgable members here to verify that the X300 does indeed use OBDII. I know it wasn't standardized until the late 90's if so I'm pleased to hear that getting diagnostic info for my 95 xj6 will be a snap.
Old Aug 29, 2014 | 09:44 AM
  #31
Dave2254's Avatar
Hi no sadly the old girl still not starting, i recall not long before she stoped starting the alternator belt was squeeking so am in the process of changing that and if that fails new alternator. If your X300 supports OBDII there will be a port in the drivers side footwell nxt to the radio
Old Aug 29, 2014 | 10:11 AM
  #32
RJ237's Avatar
The 95 has less capability than the later years, but i have picked up a EGR code when the valve needed cleaning. My Autoenginuity does not interface with the 95, but works reasonably well with my XK8.
I have an UltraGauge for which I made bracket that slides in the seam between the center console and the dash, and keep it permanently connected to monitor the real time temp. It also has an alarm that I set to 220 deg.
Forcedair1
Feb 19, 2020 01:51 PM
xjrjag
Aug 17, 2019 03:45 AM
Terry007
Sep 24, 2015 10:36 AM
kevinl
Sep 18, 2015 11:00 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
