1996 XJ6 Stalling on Idle
Old Jun 25, 2011 | 07:21 AM
cooke's Avatar
Default Check fuel pump
Originally Posted by Enlacalle
My Jaguar sometimes stalls on idle. It usually happens when the car has reached the usual warm temperature (about 5 minutes after I turn it on). When I reach a light and stop, the RPM will dip for a few seconds and recuperate, but at other times it won't causing the stalling. There is no code. I've replaced the fuel filter, spark plugs, air filter. One particular and strange detail: when I pour a "system fuel cleaner" the problem stops until I have to refuel the car when it reaches empty. It's annoying and driving me crazy. Thanks for all your help!
Check the pressure at the fuel pump in other words CHECK THE FUEL PUMP. I just went through almost the same problem
Old Aug 9, 2011 | 08:29 AM
CrustyMarine's Avatar
I had the exact same car and problem. I replaced the Crans Sensor last night and all is GOOD with the world! Might want to try that? Hope this helps......
rusty37
Apr 5, 2020 07:40 PM
Terry007
Sep 24, 2015 10:36 AM
shootingbrake
Sep 23, 2015 10:54 AM
ccfulton
Sep 20, 2015 05:15 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
