1997 XJ6 fuel Line disconnect at bottom of tank?
Guest
Posts: n/a
I am trying to drop the tank on 1997 XJ6 and have everything disconnected except for the 2 fuel lines at the bottom of the tank. Looks like the plastic line are are pressure fit on to the steel lines. I tried to pry them loose but will not come off. Is there a technique or special tool that I need to use.
Appreciate all the help. Thanks, Paul
