Having a confluence of issues with my Six at the moment and unsure if related. I first encountered problems with the revs plummeting as I came to a stop, with the car struggling to not stall. This developed into occasional stalling when stopped at lights. I now also have the issue that the car is very hard to start - with it cranking for a fair while before catching and immediately dying three or four times before I can get it to run. Unsure if related.
Other than a lumpy idle, the car runs well when going with no hesitation and plenty of power.
My first thought was the CKPS, but the car does show 200rpm while cranking so is that ruled out? I’ve cleaned the TB and IACV with no improvement. Battery is very new and cranks at about 10.75V.
The fuel pump may be under performing as most critical at idle and start , has to do with minimum injector pulse width or open time
Main fuel filter change , injector cleaner in the tank ( Chevron brand ) inspect the fuel pump motor connector for burnt sockets and swap the fuel pump relay as they can have the power contacts inside burning / pitting , both signs the fuel pump giving up the goast , 43 psi fuel pressure
The CKPS on this model can show tach , but fail in the single signal being discerned in that one use of fuel pump enable
Parker's question is a good one: is your car an X300 with AJ16 engine or an XJ40 with AJ6 engine?
Both have the ZF 4HP24 transmission, which has a known issue of low transmission fluid causing engine stalling when slowing to stop or make a turn.
A common place for a major intake air leak to form on both the AJ16 and AJ6 is on the underside of the air intake elbow where it connects to the accordion hose that leads to the throttle body. If the hose clamp is over-tightened at all, it can cause the underside of the elbow to bend inward, opening a large leak for unmetered air, causing very lean fueling.
If your car is an XJ40, there is an onboard diagnostic system that may help. Please let us know which car you have.
Not sure where to go next…
You might also want to look at the deep spark plug wells that extend from the holes in the cam cover into the cylinder head.
I recently bought a 1997 X300 where the cam cover gasket and the spark plug seal gaskets had not been changed for years and years.
As a result there were huge amounts of oil down around the plugs. In some cases the plugs were completely submerged in oil.
You would remove the screws holding the cosmetic panel that covers the six coil packs, unplug the wiring connections from each coil pack, and then remove the two screws holding each of the coil packs down to the cam cover.
Once you do all of that you can pull each coil pack out so you can look down in around the spark plusg to see if this might be your problem.
There was a recent report (s ) of generic or low quality CKPSs have a spot of stumble under the bonnet so a word of caution
A good ( or at least in this test variable) CKPS will read 1300 ohms
Fault code CEL P0335 if it even shows
You can directly power the fuel pump with a jumper between socket 3 and 5
Best to use a medium wire with blade type wire ends or you will be short coming the proper current to drive a in question pump , the store can make one for you
I had a similar problem with my 96 A16 engine. I ended up changing the crank speed sensor, transmission control module and the engine control unit. It's been working fine since.
After that I'm out of ideas.
That's not diagnosis, it's the "Parts Cannon." We discourage that around here because throwing parts at a Jaguar can get very expensive and time-consuming without resolving the underlying problem.
Either the ECM or the CKPS may have been your problem (probably not both). The TCM has nothing to do with engine startup.
So it took me a while to replace the CKPS because I managed to snap the bracket on installation. Had to source and replace with an Andy bracket (what a shame!).
Unfortunately that hasn’t done anything to improve the hard start.
Could the cam sensor explain this? The car cranks and cranks with no signal from it and then makes a guess and it’s 50/50 as to whether it’s on the right stroke?
Yes, that is a possibility. You might disconnect the camshaft position sensor and see if the engine starts any differently. If not, the cam sensor (CMPS) or its wiring may be suspect.
If the ECM doesn't receive a plausible signal from the CMPS, it doesn't know from the CKPS signal alone whether the engine is at TDC for cylinder 1 or 6. So it has to determine proper ignition timing by trial and error, which can add significantly to the cranking time before the engine starts.
The Cam sensor is code PP0340 and the engine will start with the hockey puck with a small round window connector removed , albeit a couple more engine rotations vs. instataniusly , as mentioned above to do with what TDC is ignition or coming back around exhaust on 2nd piston down stroke in a 4 cycle
My P0340 cleared with connector clean
If you have the Andy bracket the CMPS should be adjusted to the timing mark on the crank toothed wheel as can be seen on front about 5 O ' clock , do not loosen the index mark pointer
Andy has a way of feeling down the oil fill cap for the # 3 valves to be in a certain position to extrapolate the # 1 being in TDC fire , or can remove valve cover to be sure
Thanks all. Unfortunately I don't have any codes which makes it all a little trickier. I am loathe to simply throw parts at the car but the behaviour is no different with the cam sensor disconnected so I suppose that's probably the next thing to swallow.
There is an adjustment to the Cam sensor unlike the Crankshaft sensor which is fixed
I was able to find the Cam sensor at the local auto parts store , but the reworked part received was iffy looking at their workmanship so put original back in with adjustment and connector cleaning and my P0340 code went away ( may have tripped once during parts disconnect rambling around under bonnet)
Quick and positive update. Replacing the cam sensor with a used unit has fixed the starting issue! It’s in exactly the same orientation as the old one, so I’m not sure what about it failed. And to clarify I cleaned up the connections first and tried that, so it wasn’t merely a poor connection.
