95 xj6 jaguar kickdown
Old Mar 8, 2016 | 12:07 AM
Keisha Markie's Avatar
Default 95 xj6 jaguar kickdown
Help please kick down cable adjusting csn someone tell me how
Old Mar 8, 2016 | 05:26 AM
Fraser Mitchell's Avatar
Hi Keisha. you've posted in the wrong forum for your car. This one is for cars built 2003 - 2009. Try posting in the XJ40 forum the one for your car. You should then get some help.
Old Mar 8, 2016 | 09:32 AM
Don B's Avatar
Hi Keisha,
Welcome to the Jaguar Forums! It's great to have you with us.
I have moved your post from the forum for the X350 to the forum for the XJ40, which is the Jaguar factory project code for your 1994 XJ6. Here you will find knowledgeable owners of similar cars.
There is no kickdown cable on your car. The transmission is electronically-controlled and kickdown is triggered by a switch under the large rubber stop button under the accelerator pedal.
I would suggest that before you mess with the kickdown switch that you first adjust your throttle cable, which stretches over time. See the photos at the link below for instructions:
Welcome to Jag-lovers - Members Photo Viewing Page
Try that first and then let us know if things have improved.
Cheers,
Don
Old Mar 8, 2016 | 10:03 AM
Okay i did make an error its a 95 do they have a kick down or do i just replace the box underneath the gas pedal
Old Mar 8, 2016 | 05:23 PM
Don B's Avatar
Hi Keisha,
I've moved your thread again, this time to the forum for the X300, which is the Jaguar factory project code for your 1995 XJ6. The transmission in the 1995 is the same as in the 1994, but the throttle cable arrangement is a little different.
Please describe the malfunction you are experiencing with as much detail as possible so we can try to give you the most helpful information. It's impossible to advise you without knowing the symptoms.
Cheers,
Don
Old Mar 9, 2016 | 04:46 PM
Malihide's Avatar
Welcome to the X300 forums!
I think I can help you with your problem. Does the transmission kick down when you push the pedal all the way to the floor and hit the button (kickdown switch) with the pedal? In normal mode, this is almost the only way it's going to change gears if the engine has already engaged 4th. If you put the car in sport mode, it should kick down one gear at about half throttle. This is normal and can be confusing if you've driven a car that gears down via the throttle cable itself. I would say that if you need to drop down a gear, flick the sport switch (S / N right by the shifter) and give her a bit, OR use the j-gate to select 3rd or 2nd depending on your speed. The kickdown switch really is meant for maximum acceleration, since you have to have the pedal matted to the floor.
If you're talking about the kickdown switch not dropping down a gear when you press it, that's another story. Likely you would need another switch, or your current one has been unplugged. But try it out first, and try sport mode as well.
Etrader
Feb 2, 2016 05:46 AM
garciapitbull
Feb 1, 2016 08:27 PM
garciapitbull
Feb 1, 2016 12:43 AM
Michael Lynn Cook
Jan 31, 2016 08:38 PM
o1xjr
Jan 28, 2016 08:29 AM
