96 xjr runs rich?
Old Oct 6, 2010 | 05:19 PM
nitropyro's Avatar
Default 96 xjr runs rich?
okay i have check engine light, idles at 700 steady, but when i drive i get black smoke and it smells rich. Any one have any ideas before i take it to the shop so they can check the o2's. oh if this helps, both mufflers were shot so i replaced them, doesn't seem to make a difference. The air cleaner seemed dirty so i took it out, that didn't seem to change any thing yet either.
Danny
Old Oct 6, 2010 | 05:36 PM
Doug's Avatar
Faulty fuel pressure regulator (leaking or allowing too much pressure) and a skewed coolant temp sensor are two possibilities.
Cracked exhaust manifolds (common on these cars) can trick the oxy sensors into thinking the mxiture is lean....and they'll command extra fuel.
Do you have a scan tool? Knowing the trouble codes would help
Old Oct 6, 2010 | 05:46 PM
nitropyro's Avatar
sorry i typed too fast there is NO check engine light on..
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
XJsc-guy
Sep 25, 2015 11:09 AM
philwarner
Sep 6, 2015 11:10 PM
