ABS fault. Ideas needed.
Old Jan 9, 2026 | 12:20 PM
Parker 7's Avatar
To open the wheel sensors themselves as the metal cap over / glued to the plastic bodied sensor probably won't " give you much "
When I looked at my 1 damaged ( cap pulled off ) in removed sensor , the internal dimensions where either too small for repair or " potted " can't accurately recall to tell you
But do record the raised letters part #s for referencing if wrong against part list as there was a change in part #s during X300 production , so that makes X number of possible part #s in the mix , lefts do not work on rights and vice versa ( has to do with spinning target toothed reluctor as the sensor is a inductor just like the crankshaft position sensor ) moving across the face direction as sensor is mounted )
I once saw a response back to me as he saw 600 ohms as a basic meter test on whole group of 4 sensors and his worked
xjr2014_de
Sep 25, 2025 07:17 AM
captainobvious1
Jun 1, 2024 06:19 PM
EZDriver
Apr 30, 2022 12:29 PM
jagosaurus
Apr 29, 2022 07:14 PM
Windycityx
Oct 28, 2013 07:53 AM
