I my ABS stays lit (most of the time)
Yesterday It went out and my cruise control worked. Now it is back on and up to its old tricks. What kind of connection is causing this, and where is it located?
You should scan for codes to see why. It can come on for several reasons. BTW, have you repaired/refurbished your ABS module yet?
No, I have yet to refurbish my ABS module. It worked for a few miles and then relit. This sounds as if it is a connection problem.
But - do check battery state first as advised.
