I my ABS stays lit (most of the time)
Old May 31, 2024 | 05:39 PM
captainobvious1's Avatar
Question I my ABS stays lit (most of the time)
Yesterday It went out and my cruise control worked. Now it is back on and up to its old tricks. What kind of connection is causing this, and where is it located?
Old Jun 1, 2024 | 12:39 AM
RichardS's Avatar
How old is the battery? What is it's resting voltage? Is it fully charged?
Richard
Old Jun 1, 2024 | 03:06 AM
Y2KJag's Avatar
You should scan for codes to see why. It can come on for several reasons. BTW, have you repaired/refurbished your ABS module yet?
Old Jun 1, 2024 | 04:16 PM
No, I have yet to refurbish my ABS module. It worked for a few miles and then relit. This sounds as if it is a connection problem.
Old Jun 1, 2024 | 06:19 PM
michaelh's Avatar
It may well be so:- the extensions to the front wheel sensors can fail with the repeated flexing. There's also the pump motor connectors internal to the ABS module that go intermittent (codes may not show on a simple OBD reader).
But - do check battery state first as advised.
garyfdl
Sep 12, 2022 09:16 AM
otherman
Aug 21, 2017 07:54 AM
Striker27
Apr 5, 2013 08:25 PM
JagXster
Mar 1, 2012 01:15 PM
BensX-type
Mar 14, 2010 07:56 AM
