ABS Light XJ6 1996 help
Old Mar 20, 2012 | 08:21 PM
daboss085's Avatar
Default ABS Light XJ6 1996 help
hello, I have had a constant ABS light on my 96 x300 for a few
weeks now. I scanned the code and it read a C1095. I spoke to a
local Jag Mechanic that has been repairing jags for over 20 years
and he says that you cannot resoder the circuit board like you can
on the X308's. He also says that in all his years of repairing
X300's he has never encountered a problem with the abs. I have seen
many people post that there light comes on, and they send the
circuit board out for repair. He also told me that the anti-lock
is "Really" only for the snow climate, being that I live in South
Florida I dont need to fix the issue is what he said. Does anyone
agree with him? I hate the light, but if I dont have to really fix
it, I can just pull the bulb from the speedometer. Thank you.
Old Mar 21, 2012 | 10:33 AM
etaent's Avatar
I also had the same issue, however i never got it scanned, funds are too low. So i pulled out my speedo, took the bulb out and changed the illumination bulbs for the speedometer to leds while i was at it. Now no more light, and still great brakes. However in response to your other comment, anti-lock brakes are not just for snowy weather. Antilock brakes are there to prevent your brakes from locking up in the event of an accident or rapid hard braking. In the past, when you slammed on your brakes they could lock up causing you to go into an uncontrollable skid. Anti lock brakes work with a pump that forces fluid into the calipers forcing them to open in the event that they lock. This is why it is also important that your wheel sensors are functioning because thats how your cars computer knows if a brake has locked up. Is it absolutely necessary to get this fixed in the short term? No, but in the long term i would look to fix it. When i get more funds i will definitely be fixing mine!
Old Mar 21, 2012 | 01:28 PM
xjrguy's Avatar
No, he's not right; and I wouldn't have him working on my car with that level of knowledge.
If that ABS light is on, you have NO ABS brake function, it is inhibited.
Yes, you can repair that circuit board, though it is a little more involved than the later cars. I made something up on that sometime back and I thought it was on here somewhere, but I can't find it.
Here's a link for download.
https://www.myotherdrive.com/dyn/fil...ABS+Repair.pdf
Good luck!
Old Mar 21, 2012 | 04:12 PM
daboss085's Avatar
thanks xjrguy, I am not that good at removing the modules and fixing them, so I would like to send it out for repair, you know or anyone know of a place I can send the unit out to?
Old Mar 21, 2012 | 04:17 PM
xjrguy's Avatar
These are two of the repair facilities we had used before I took it on myself.
BBA reman. ABS, ecu's, throttle bodies, air mass meters, and catalytic converters
ModuleMaster
Good luck!
Old Mar 21, 2012 | 08:55 PM
daboss085's Avatar
i was on the modulemaster site and only see jags 1997 and newer. I dont see the module abs for my 96 xj6... know anything?
Old Mar 21, 2012 | 09:19 PM
aholbro1's Avatar
Call or email them. Their site used to say only 96-97 clock modules. Having a '95 and believing the clock modules were identical, I called them up to ask why they couldn't have-a-go at a 95? and the nice lady assured me they did them, but there was a typo on the website. Just call and ask. Tell them to see XRRGuy's post and/or Bob's that I linked for you in your other ABS Thread if they are trepidatious..they can do it.
Old Apr 5, 2012 | 10:15 AM
marfdave's Avatar
My light comes on and off. Haven't had it checked as it just started to happen. I'll have to wait 'til it comes back on and I can get it coded.
Old Apr 5, 2012 | 03:24 PM
motorcarman's Avatar
The fault is logged in the module whether the light is on or not. If the light was on it is still in the module as a fault.
bob gauff
Old Nov 10, 2012 | 06:58 PM
69duke's Avatar
Hey guys. Well here I am again. You have saved my butt several times so maybe you can again. I was driving about 45 MPH and heard a very loud thump from the right front. Then the ABS Light came on. I stopped and checked to see if a tire had separated but tires were ok. Car drives and stops ok no problems. So what do yall think?
Old Nov 11, 2012 | 03:27 PM
steven300's Avatar
hi motorcarman,if i send my 95 and 96 xj6 abs module's out for repair and the light stays on,should i take them to the dealer...steve.
Old Nov 11, 2012 | 05:09 PM
Doug's Avatar
I wonder if you hit something on the road? Couldn't hurt to remove the wheel(s) and look for damage to the wheel sensor wiring.
Costs nothing to have a look.
Old Nov 12, 2012 | 06:06 AM
69duke's Avatar
Thanks for the response Doug I did just that. I pulled both wheels and didnt see anything that looked like I ran over anything but that could have been the case. It was dark so its possible. The Anti Brake light went off by itself. The only thing I could see was a frayed wire going to the brake on the left side. The wheel bearings were a little loose but probably been that way for awhile. I repaired the wire and will wait and see. I didnt know that light was like a Check Engine Light for other cars. I ran the OBD II and came up with a misfire cylinder two so I got that to work on.
Thanks again
Duke
Old Nov 12, 2012 | 08:34 AM
steveinfrance's Avatar
Duke, you won't get an ODB code from the ABS system, it uses 'C' codes.
Almost certainly you hit something as Doug said and it damaged the ABS cable - maybe producing a momentary short enough to trigger the ABS warning..
I believe they're cheap + easy to replace.
Old Nov 12, 2012 | 08:01 PM
doc's Avatar
doc
Module master are great sent mine from Australia they fixed it on my 95 XJR am now having problems with the traction control light coming on if I go over 220 k,s per hour
will check to see if they repair them would rather not have traction control anyway but hate the light coming on
I think the traction control control's the cruise control as well that I really want to keep LOL
Old Nov 12, 2012 | 08:45 PM
Doug's Avatar
I must be the only person who likes having traction control ! :-)
I don't think so....but if there's an ABS/TC fault the cruise control might be inhibited from engaging.
Old Nov 12, 2012 | 09:15 PM
xjrguy's Avatar
Nope! I'm with you Doug.......Traction Control is your friend.
Traction/Cruise? Right again, Traction Control only intervenes to back off the throttle, regardless of driver input. Right side of engine compartment.
Cruise control is the vacuum servo that opens the throttle and is controlled by the valve and vacuum pump motor behind the LH headlamps.
Cheers,
Old Nov 12, 2012 | 09:34 PM
Doug's Avatar
XJRguy,
IS there an electronic inhibit to prevent cruise control from operating if there's an ABS/TC fault? It seems to me that I've been unable to use my c/c if the ABS light is on....but I may be confusing this with another car.
I guess I *could* just RTFM :-)
Old Nov 13, 2012 | 05:32 AM
caldercay's Avatar
XJRguy,
My ABS/TC lights are lit, but i can still use the C.Control
Old Nov 13, 2012 | 08:28 AM
xjrguy's Avatar
XJRguy,
On the X300, usually not. I think the exception is if there is a REAR wheel speed sensor fault. I think its the RR sensor that is the main input for road speed. Loose it and I think the cruise fails. If the RR fails, the ABS module transmits the LR as a substitute, but I think the cruise will still be inop.
On the later V8 cars, some ABS faults will also set the CHECK ENGINE light, not so with the 6 cyl. The V8 systems will disable certain component monitors with some ABS faults. If OBDII monitors are disabled, they are obligated to turn on the Check Engine Light.
Cheers,
