ABS module replacement brake bleeding question
Old Apr 30, 2026 | 10:03 PM
olivermarks's Avatar
Default ABS module replacement brake bleeding question
I have the 3 abs bolts disconnected and have a (hopefully) repaired module ready to go in.
I need to replace my brake fluid so I was wondering if actually removing the lines to the abs and then reconnecting it all up and bleeding the brakes is going to cause a bunch of issues, or is it pretty straight forward? I can do the bending the brake lines method and not disconnect them just wondering which is best. TIA
Old May 1, 2026 | 03:13 AM
V126man's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
I just bent the lines. Not that difficult and no bleeding required.
Like you, I was concerned about problems bleeding the lines if I removed them.
Old May 1, 2026 | 08:47 AM
Parker 7's Avatar
The official procedure is in the I found and put up in 6 parts very large 821 page or so X300 XJ6 - XJ12 Vehicle Service Manual , section 8 without looking up
Repair Manual - Jaguar Forums - Jaguar Enthusiasts Forum
On aircraft brake bleeding we had a flex hose on the bleeds that put into a U shape , when brakes relaxed it would not draw air back into brake wheel cylinders and up , but we had plenty of free brake fluid which was actually whole aircraft 3000 psi hydraulic fluid ( flight controls and gear extension )
I have not bleed brakes on the X300 , but all I heard from my never helping neighbor was excuses not to work on it and not solutions , he made his living as a mechanic somehow but all I saw was a wrench bender with no thought or reasoning
martinrupp
Oct 31, 2025 04:51 PM
P.B.
XJ40 ( XJ81 )
Feb 9, 2024 06:12 AM
RDMinor
Jun 6, 2017 10:29 PM
WaterDragon
Aug 14, 2012 07:33 AM
Simprof
Jan 22, 2012 09:35 AM
