abs/trac fail lights have come on
Old Mar 3, 2013 | 05:10 PM
smgdata's Avatar
Default abs/trac fail lights have come on
so today outa know where my lights came on. nit happy.
anyone know of any test I could do to see why they are now on?
Old Mar 3, 2013 | 05:57 PM
Doug's Avatar
Not "tests", but.....
Sometimes removing and re-seating the trac and ABS connections mysterious solves the problem. This has worked for me a couple of times.
Sometimes cleaning the wheel speed sensors does the trick
Sometimes a hard reset does the trick
Sometimes none of the above helps and you need to find someone with a scan tool that'll read ABS codes.
Old Mar 3, 2013 | 08:39 PM
smgdata's Avatar
hahha thanks for the tips Doug
Old Mar 5, 2013 | 07:09 PM
smgdata's Avatar
well i unplugged/ plugged in things. i noticed it does the self check when i start off i feel in itn the peddle. but after 10mph to 20 the lights come on.
when i unplug any sensr and start the car the lights are on. plug in lights off.
Old Mar 8, 2013 | 05:00 PM
conradsgym's Avatar
How do you do a hard reset, I have the same problem
Old Mar 8, 2013 | 06:52 PM
smgdata's Avatar
I think undo the battery and put the two wires 2gether? feel free to chime in anyone
Old Mar 8, 2013 | 07:47 PM
RJ237's Avatar
You only need to take the ground off the battery, then touch it to the positive terminal, or if it's held with a tie wrap so it won't reach, use a screwdriver or other metal object.
Old Mar 8, 2013 | 08:34 PM
Gus's Avatar
Gus
A hard reset might help but chances are it will not. You should see if you can get the codes but if that is not an option then testing is the way to go. I have a procedure for running tests from the ABS plug for an xk8 and it might give you what you need for testing yours. I also have a procedure for repairing the ABC module if it is necessary.
Often when the ABS light appears after the car has been started and it moves about 20 yards is a good indication the module needs repair.
Link for ABS repair Welcome To Auto ECU Inc.
Link Oneline http://jagrepair.com/images/AutoRepa.../jagxj1996.pdf
Old Mar 9, 2013 | 01:52 AM
smgdata's Avatar
dang i hope my module isnt dead. they are differnt on the x300 then the later ones
Old Mar 9, 2013 | 08:38 AM
Gus's Avatar
Gus
My 1995 XJ6 had the same problem and at the time I replaced the ABS unit next time I would opt for the rebuild.
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
Mosers63
Sep 6, 2015 02:53 PM
jaguarbill
Sep 5, 2015 11:43 AM
rachelstr
Sep 3, 2015 12:59 PM
