ABS Wheel sensor problem
Old Dec 26, 2014 | 02:51 PM
cygnus x1's Avatar
Default ABS Wheel sensor problem
I had to replace the L/R hub carrier and hub, so I had to remove the ABS wheel sensor. It was working fine but after reinstallation in the new hub carrier, I get several warning lights and the speedo does not work. How do you test the sensor? What is it, photo-diode, hall sensor?? Can it be checked with a vom, or is a scope necessary?
Old Dec 26, 2014 | 02:59 PM
RJ237's Avatar
It's more likely the wire has an internal break due to flexing and age. But just check the resistance across the pins, it will probably be about 1000 ohm, but I'm not positive. Even with an ohmeter you can check the check that it fluctuates when you rotate the wheel.
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
tberg
Aug 31, 2015 04:33 PM
NinoGrimace
Aug 26, 2015 05:15 AM
